Home » Audio » Group Build » AudioeXpress
AudioeXpress [message #30619] Sun, 20 February 2005 06:57 Go to next message
Say; check out the new issue. Guy builds a great amp with peerless trans and 71a tube transformer coupled with big oil caps. Battery Bias. He uses a PP trans in SE mode.
Re: AudioeXpress [message #30621 is a reply to message #30619] Sun, 20 February 2005 07:06 Go to previous messageGo to next message
my intro subscription ran out. Must renew I think. Which Peerless TX?
regards,
Douglas
Re: AudioeXpress [message #30622 is a reply to message #30621] Sun, 20 February 2005 08:48 Go to previous messageGo to next message
He calls it an Altec Lansing/Peerless 4722. With a Stancor 8054 PP OPT. wired for SE.
He also says you can sub a Hammond 808. Nice Power supply circuit. Actually the whole thing kinda resembles Guinevere a little, although it's an amplifier. The bad thing; now there will be a rush on good old iron. I gotta admitt Douglas you're ahead of your time!
I had some reservations but in the past few weeks I have seen the light.
let there be a rush... [message #30624 is a reply to message #30622] Sun, 20 February 2005 09:13 Go to previous messageGo to next message
Hey-Hey!!!,
IMO the old power Iron is of far less import unless you are buying it for the potting cans. It is usually designed with lower primary voltage. Running 115 Iron on 120-125 is not ususlly a good idea in audio apps.
6.3 turns into 6.6 or worse, and similar things happen to the HV. not always bad, just so you realize what is going on in the design stages.
you had reservations about ME? well I never....:-)
regards,
Douglas
shameless plug: the ART shirts are really nice.
Re: let there be a rush... [message #30626 is a reply to message #30624] Sun, 20 February 2005 09:39 Go to previous messageGo to next message
Can't help it; it's my nature. However; once I am on your side, I am loyal . I forgot to say the amp uses an input trans. Thats the peerless. How come the big oiler has four solder tabs?
I just bought the BBC recordings of Led Zepplin Live. Real good sounding. I know you are a fan.
Shameless Plug; sounds like Click and Clack The Tappett Brothers.
lov 'em... [message #30628 is a reply to message #30626] Sun, 20 February 2005 11:31 Go to previous message
they do what is usually impossible: diagnoses from remote. quite the pair, and I listen when I can.
regards,
Douglas
it's a good thing my wife does not wear Sz. L T's, or I'd have to get another!
Previous Topic: Stupid Question #1
Next Topic: IN 5408 Diodes
Current Time: Sun Apr 28 17:07:55 CDT 2024
