Home » Audio » Group Build » 6v6v6
6v6v6 [message #30486] Sat, 12 February 2005 07:11 Go to next message
So is the 100ma rating on the power trans adequate to run PP 6v6's?
Re: 6v6v6 [message #30490 is a reply to message #30486] Sat, 12 February 2005 13:45 Go to previous messageGo to next message
Yes, but...:-) See some tube data for 6V6 and EL84 (similarly). With "standing current" of about 30-40 mA per tube, and Ua of 250-300V we can expect about 4-5 W in PP triode A class, or about double in UL. Pentode and AB class ~15W or little more. With max. power, our 60-80 mA "standing current" would rise very close to the 100mA, and better use "economical" driver tube that work with only a few mA...
6v6x2 [message #30516 is a reply to message #30490] Sun, 13 February 2005 18:45 Go to previous message
Hey-Hey!!!,
I think the L-C filter would gain us something, especially if a conservative rectifier was used. 400 volts @ 100 mA is 40 watts. 3A of 6.3 and 5 VAC is about 30 watts. 70VA core will have more to give the HV is full use of the heater taps is not made. It will not be all that close I suspect.
Class A bias with 6V6's in U-L and using the middle taps and a 6BK7B driver pair( figure ~6 mA for that stage or so ) will give B+ of ~240VDC. No biggie....
regards,
Douglas
Previous Topic: CCS built
Next Topic: RIAA preamp?
Current Time: Mon May 13 03:49:08 CDT 2024
