Home » Audio » Group Build » RIAA preamp?
RIAA preamp? [message #30375] Thu, 03 February 2005 11:39 Go to next message
Hey, just a thought - oversized PS with free 2x300V winding, big chasis - why not put RIAA preamp inside, selectable to the input (100k pot) of the line preamp?
I tinkered for a few hours about this idea today - I tried to be as simple as possible ("all in one go" EQ, just one double triode), and without "exotic", hard to find values for the RIAA EQ - R1, R2, C1, C2. The little "trick" is to find the C1 cap with little lower value then standard 10nF, about 9,76 nF (not a big problem actually, most of the standard 10 & 20 % caps I tried are little lower in value). Then, with our RIAA equations: R1C1=2187uS, R1C2=750uS, R2C1=318uS, C1/C2=2,916 we can find:
R1=224 kOhms - our Rout from the first stage is about 3k, and we can use standard E96 value, 221k/1% (even E24 value 220k with small selection)
R2=32,58 kOhms - little tricky, we can select between some 33k resistors, or use some cobination, or just use E96 value 32,4k
C2=3,347 nF - "input" capacitance of the second stage is about 47pF, and just use standard 3,3nF cap of your choice (2,5% tol. if possible)
If we want to use this preamp to drive more then few cm of cable, then we can use active DN2540 load for R7=15k, and use low imp. out.
Theoretical amplification is about 80 times/1k, more then enough for "normal" MM cartridges + our line stage.
Well, this is just some thoughts/computing/simulations (almost perfect, of course:-)). Is not a problem to build it, problem is that I don`t have the quality measuring devices to actually try RIAA accuracy:-(. Maybe...hm...Doug?
And, BTW - some other tubes besides E188/7308 can be implemented, probably E180CC, maybe 6N1P or so... Both triodes work with rel. high current, Ia1=10mA, Ia2=9,5mA.
Thoughts?
Re: RIAA preamp? [message #30376 is a reply to message #30375] Thu, 03 February 2005 13:12 Go to previous messageGo to next message
Nice idea; what about shielding?
Re: RIAA preamp? [message #30377 is a reply to message #30376] Thu, 03 February 2005 14:46 Go to previous messageGo to next message
Not so sure what you mean, maybe shielded cable? I`d build it close to the input pot, just a few cm of wire. Tube socket can be PTFE material or so + tube shield...
I posted this schematic in hope that some discussion can be made... at the end, maybe someone actually build it and try it... I hope that direct coupling between the stages have more advantages then flaws... then cathode decoupling cap C3 (220uF/160V-probably electrolitic) hasn`t large negative impact on sound (can be avoid with active load and Mu-out), etc.
Re: RIAA preamp? [message #30378 is a reply to message #30377] Thu, 03 February 2005 15:18 Go to previous messageGo to next message
I would like to combine the two and get rid of one box on the shelf.
Re: RIAA preamp? [message #30447 is a reply to message #30375] Fri, 11 February 2005 08:05 Go to previous messageGo to next message
Well, it looks good to me. I have a few ideas. First is to use a Guinevere-style plate load on the final stage. It offers the high drive capability and a little more free gain without interfering with the RIAA parameters.
Second, I'd suggest the 6BQ7A/6BK7B valve. It is inexpensivew and a little higher gain. Cg-a is comaprable to any of the mentioned alternatives.
regards,
Douglas
Re: RIAA preamp? [message #30467 is a reply to message #30447] Fri, 11 February 2005 14:24 Go to previous messageGo to next message
Close enough to ECC180 and then close enough to E180CC I suggested?:-)
I hope that I`ll find some time to breadbord E188CC version first and see is it good enough. If yes, E180CC (and little correction for ECC180/6BQ7-A if necessary) is in order... I just don`t have the instruments good enough for checking RIAA accuracy, that`s the problem. Any idea? Any desire to breadbord it?
something like it.... [message #30475 is a reply to message #30467] Fri, 11 February 2005 15:27 Go to previous messageGo to next message
I am going to try for a two-stage valve pre for MC. Cascode of the front end stage. Probably a pair of triode strapped, high gm pentodes. Get the first stage gain in neighborhood of 200:1 and feed the RIAA filter and end with a CCS-loaded 6BQ7 perhaps. Getting half or a third of mu-squared from a cascode is not too difficult I think.
the troubles I can see from here are mainly the high output z of the cascode stage and the correspondingly high z RIAA EQ. The Guinevere-style plate load will do a good job of driving cables.
I may decide to put in a variable capacitance in the front, as the cascode will be nearly free of Miller effects.
Still looking at it.
regards,
Douglas
That and noise....heh-heh-heh!
6EJ7 [message #30476 is a reply to message #30375] Fri, 11 February 2005 18:28 Go to previous messageGo to next message
Hey-Hey!!!,
Been looking at the sheet to the EF184/6EJ7. Nice, mu ov 60 and gm of 15 mA/V in triode connection. That leaves a plate z of 4k, which is acceptable.
Do you know of a sheet with its triode curves? With that I could generate the cascode plate curves and see what gain I could realize. mu-squared is unbelievable ( 3600 ). If I could get 10% of that I'd be in business.
regards,
Douglas
Re: 6EJ7/EF184 [message #30485 is a reply to message #30476] Sat, 12 February 2005 06:37 Go to previous messageGo to next message
Hey, of course, here`s the link - www pages by Tom Schlangen (sometimes it is useful to read rec.audio.tubes threads :-)), down there: "Tubes Technical data".
Don`t tell anybody, but IMO - EF184 is cheap, linear and plentifull - I have some TFK, Valvo and Siemens.
Re: 6EJ7 cascode A [message #30491 is a reply to message #30476] Sat, 12 February 2005 14:27 Go to previous messageGo to previous message
You probably know this, but just in case... Amplification of the cascode is A=gm*Ra, just like in pentode, where gm is gm of "compound device, quasy pentode", or A~gm1*Ra , where gm1 is transconductance of the lower triode, IME - always gives a little "optimistic" values. With unbypassed Rk, gm1`~gm/3, and with Ra~8k2 - A~40.
Of course, there are "full" formulas for this ("Valve Amplifiers", RDH, "Vacuum tube amplifiers"). For complicated cascode versions there`s always SPICE (hey, I have EF184 pentode 3f4 model - if you feel desire for it...).
I also thought about cascode RIAA, but that Rout...
Previous Topic: 6v6v6
Next Topic: Does anyone want me to go thru grounding? (nt)
Current Time: Sun May 12 22:34:38 CDT 2024
