Home » Audio » Group Build » Chassis polishing
Chassis polishing [message #30331] Sun, 30 January 2005 08:10 Go to next message
Leave it to me to re-invent my own wheels. I got all the holes drilled in the top plate of the new linestage and began taking out all the nicks and dings in the oh-so-soft Aluminium.
The last stage I did was with 600 wet/dry and it plugged up the paper fairly fast dry. So to the sink, little bit of dish soap and warm water. Paper cut for something like 4x as long and finish was better. Going to do a last run with 800 or 1200 grit. It ought to be pretty smooth and shiny.
You'd think I'd remember more from my youth spend prepping cars for paint in a body shop...maybe the solvent got through the mask more than I thought.
regards,
Douglas
Sniffin` glue... [message #30335 is a reply to message #30331] Sun, 30 January 2005 10:40 Go to previous messageGo to next message
Or maybe all that electro-shocks?
I use empty 19" rack cases (1,6 mm steel), drill/punch the holes, tubes on the top plate, electronics inside from the other side of the top plate. You can open the bottom plate and fix/measure the thing...
For small projects, case from the PC PS is good...
Re: Sniffin` glue... [message #30342 is a reply to message #30335] Sun, 30 January 2005 13:09 Go to previous message
Hey!!!!!!, I haven't shocked myself in at least two days...
regards,
Douglas
Previous Topic: Order the transformer NOW
Next Topic: Stereo chassis or mono's?
Current Time: Mon May 13 04:57:17 CDT 2024
