Home » Audio » Group Build » Trans order let's try to get 5
Trans order let's try to get 5 [message #30281] Tue, 25 January 2005 21:28 Go to next message
Hi guy's
Lets put a call our and try to get one more. Without 5 there is no discount. No discount and I would spec mine a little diffrent.
But I will stick with the group if we can do it.
what I was thinking is change the 5v to 6.3 Could pad it down if I realy needed 5v...John
suggestion... [message #30282 is a reply to message #30281] Wed, 26 January 2005 04:39 Go to previous messageGo to next message
call Phil and see if he'll cut the price for a run of four...
regards,
Douglas
I know I'm late to the party [message #30283 is a reply to message #30282] Wed, 26 January 2005 09:02 Go to previous messageGo to next message
BrownEyes is currently offline  BrownEyes
and I certainly don't want to throw a monkey wrench into the plans Doug. But if low(est) cost is an issue perhaps you might consider a standard off the wall 120 by 240 transformer. With todays higher line voltage and especially if it's oversized a bit I'd expect around 250-260VAC out. Into a choke say ~ 230VDC and into a cap ~ 350VDC with solid state diodes. Then get the Rat Shack heater transformer. Just an idea...too bad I didn't know about this idea earlier as I suppose it's a little late for such ideas.
Russ
I'll call Heyboer at 1 PM EST for 4 pc pricing (nt) [message #30284 is a reply to message #30281] Wed, 26 January 2005 09:56 Go to previous messageGo to next message
He cut the price (nt) [message #30285 is a reply to message #30282] Wed, 26 January 2005 11:26 Go to previous messageGo to next message
the party [message #30288 is a reply to message #30283] Wed, 26 January 2005 11:58 Go to previous messageGo to next message
Hey Russ,
The party, as I understand it, changed its view on low cost in order to get some extended flexability. Heating a 6.3V cathode with 5V is another option available too. The triple HV windigs offer L.C voltage from ~190 to 320 with a simple full wave. Other combinations on up to 800vac into a full bridge can be used as well.
Besides, any ideas are welcome, and can be applied of they will merge well with the project.
regards,
Douglas
Re: the party [message #30291 is a reply to message #30288] Wed, 26 January 2005 17:27 Go to previous messageGo to next message
So; are we all Party Members? Sounds somewhat subversive.
Might as Well Party... [message #30292 is a reply to message #30291] Wed, 26 January 2005 17:58 Go to previous messageGo to next message
doesn't sound so subversive to me. From a 'T' shirt I got at a Grateful Dead Show in Philadelphia. Presidential-style seal with a steal-your-face...
I think it got sent to the rag bag in the sky after a botched oil change on my Diesel P/U.
regards,
Douglas
Re: Might as Well Party... [message #30293 is a reply to message #30292] Wed, 26 January 2005 19:02 Go to previous messageGo to next message
The party member thing; you know back in the day; Joe M'Carthy, 1950's, ohh never mind.
Nice to know the spirit behind Guinevere links someway to the Dead. I saw them once in Ames, Iowa. They began to play Box of Rain; and it started to rain; later on they went into China Cat Sunflower and at the Sun Will Shine Part; the sun came out. People on dangerous chemicals began to shout;"Jerry can control the wheather, man!"
Sad to hear of the demise of the shirt.
Re: Might as Well Party... [message #30301 is a reply to message #30293] Thu, 27 January 2005 05:57 Go to previous messageGo to previous message
No, their songs are so long that wheather changes few times trough one or two...
Not the fan sorry,
Stooges/Iggy?
Previous Topic: trans order
Next Topic: Layout
Current Time: Sat Feb 07 23:51:10 CST 2026
