is 200w/side enough. [message #27918] |
Mon, 26 July 2004 06:01 |
Andy G
Messages: 68 Registered: May 2009
Viscount |
I do small bands mainly in pubs and small clubs. I am currently running a pair of speakers using a 2 Eminence Kappa 12's, this is usually enough for my purposes. http://users.tpg.com.au/users/gradds/twinkappa1.jpgThere have been a couple of time recently where I thought some extra down the bottom end would be nice, and would ease the load on the main bins. I would run them from the sub out of the Behringer FBQ 3120, through a separate amp. I have a pair of the following drivers that I am not really using, http://users.tpg.com.au/users/gradds/jaycar%20PA15.jpg and was considering using them to provide the extra low end. Just not sure if they will make much difference??
Re: PS... [message #27920 is a reply to message #27919] |
Mon, 26 July 2004 10:07 |
Messages: 18695 Registered: January 2001
Yeah, I'm with you on this one. You might be able to put them in an EBS cabinet or maybe a bandpass. But without running the numbers, my guess is that they are really intended for large sealed boxes. That means EBS would probably work too, but I'm not sure you're going to get a lot of deep bass out of them. On the other hand, below 100Hz, a subwoofer placed underneath near the mains is going to sum pretty well, so any additional output will help. If you already have the speakers, it seems like it couldn't hurt to give them a try. Just don't blow 'em, and if they don't work well in this application, you can use them for something else.
The Jaycar PA15 [message #27921 is a reply to message #27920] |
Mon, 26 July 2004 15:14 |
Andy G
Viscount |
is a really smooth driver, I have them in a 15" + horn box at the moment, but generally find myself using then twin kappa 12s because of the large difference in headroom. ie the twin kappa goes lots louder, being a 4 ohm box helps too!! I will probably try the Jaycar PA15s as some bass boost just to see if it works. The other option is buying some new 15" drivers, but I'm on student wages at the moment:-(( Those Eminenece Magnum HO's look rather nice in a smallish box !!
If so [message #27990 is a reply to message #27933] |
Mon, 08 November 2004 00:34 |
Mike.e
Messages: 471 Registered: May 2009
Illuminati (1st Degree) |
is 400w/channel enough for 20 or 40people ? and 800w/channel enough for 40 or 80people...Id be more interesting in -System sensitivity -Boundarys
