Home » Audio » Pro Sound » What's a good light speaker?
What's a good light speaker? [message #27556] Thu, 28 February 2008 06:42 Go to next message
Dave Colman is currently offline  Dave Colman
I've odered a Delta-Memotron M15 Amp Custom option, but can't decide
which speaker I want fitted!
The guys building my amp, need to know my choice within a couple of
weeks.
They are all guitarists too, and have offered some suggestions.
But I need some second opinions.
They offer standard "Vintage" (Celestion Blue) or "Lite"
(Celestion Neo) Amps. The "Lite" only weighs 15.5Kg.
I need a lightweight amp but I've heard that the Neo speakers are a bit
harsh at the top-end.
Anyone know a good vintage sounding 12" speaker that doesn't weigh a ton?
Re: What's a good light speaker? [message #27559 is a reply to message #27556] Sun, 02 March 2008 19:53 Go to previous messageGo to next message
Bender is currently offline  Bender
My personal favorite is, believe it or not, the rocket 80 celestion. Made in China, but it totally nails the old classic g12 sound.
Re: What's a good light speaker? [message #27561 is a reply to message #27556] Sat, 08 March 2008 13:01 Go to previous message
Gary- is currently offline  Gary-
Hi, I'm brand new to the forum. I saw your post and thought that I would suggest a Jensen Neo. I have two amps that use them. One has a 10" and the other has a 12". These speakers are very good once they are broken in, however, can sound a little harsh at first. The 10" speaker took more time than the 12" to break in. I'm not sure if it was due to cone size, wattage, or a combination. The amp with the 10" speaker is a 15 watt amp and is just 21 lbs. and the other is a 60 watt amp which is around 31 lbs. Both are tube amps.
If you can find a Neo that is broken in, take a listen and see if it fits what you are looking for.
Previous Topic: Marshall Artist 4203
Next Topic: newbie amp question
Current Time: Fri Apr 26 00:05:50 CDT 2024
