Home » Audio » Pro Sound » I want to build a Small Class A tube amp .
I want to build a Small Class A tube amp . [message #26935] Fri, 10 December 2004 15:39 Go to next message
JMONEY is currently offline  JMONEY
I want to build a small Class A tube amp. For studio work. I have a Fender Champ size enclosuer for it. As far a controls go. I just want a Volume Bass MID & treble controls. I want a Clean "hi fi " sound. Plenty of headroom.
Re: I want to build a Small Class A tube amp . [message #26936 is a reply to message #26935] Sat, 11 December 2004 18:38 Go to previous messageGo to next message
How much power do you want? Have you checked into any of the kits? Seems like I saw some schematics in the posts here as well, so you could probably roll your own that way as well. But what kind of power are you expecting?
Re: I want to build a Small Class A tube amp . [message #26937 is a reply to message #26936] Sat, 11 December 2004 20:10 Go to previous messageGo to next message
I want something from 5-10 watts. I think the kits I have seen are too pricey. I prefer more choices when it comes to parts,ect.Thanks for the reply!
Re: I want to build a Small Class A tube amp . [message #26938 is a reply to message #26937] Sun, 12 December 2004 00:40 Go to previous messageGo to next message
I guess the 2A3's max out about 3 watts when used Class A. If that's enough, you can build an amplifer pretty cheaply.
Re: I want to build a Small Class A tube amp . [message #26939 is a reply to message #26938] Sun, 12 December 2004 00:43 Go to previous messageGo to next message
Where can I find the schem ?
Re: I want to build a Small Class A tube amp . [message #26940 is a reply to message #26939] Sun, 12 December 2004 06:59 Go to previous messageGo to next message
Here are a few:
Re: I want to build a Small Class A tube amp . [message #26951 is a reply to message #26940] Sat, 18 December 2004 07:14 Go to previous messageGo to next message
Check out Angela Instruments' website for their Super Single Ended guitar amp project. It's essentially a blackface Fender, which of course will give you a tremendous clean sound.
Thermionic
Re: I want to build a Small Class A tube amp . [message #26952 is a reply to message #26951] Sun, 19 December 2004 02:27 Go to previous messageGo to next message
Cool, thanks!
I'm still itching to see some of your designs!
Re: I want to build a Small Class A tube amp . [message #26956 is a reply to message #26952] Mon, 20 December 2004 22:24 Go to previous messageGo to next message
Say Wayne, I'll post a pic of a hi-fi amp I'm working on for a customer when it's finished. Just a cheesy little cheapo beater EL84 PP amp for a second bedroom system, nothing special.
I'll be building some of "the good stuff" after that, including a copy of my EL34 PP design. It uses a battery biased 6C45 per channel, choke-loaded parafeed through a silver foil/paper in oil cap into a mu-metal phase inverter transformer. The cathode biased PP pair of EL34s are switchable between triode and ultralinear, feeding the speaks through a Plitron toroidal OPT.
The HEXFRED rectified main power supply is a stiff, choke input monster with very low impedance. The preamp tubes have a separate tube rctified supply with motor run oil caps. I also use separate filament trannies. It's a real killer diller, and a real backbreaker at nearly 60 pounds too! Maybe I'll show up at one of the shindigs in Tulsa with one someday!
Thermionic
Sweet! [message #26957 is a reply to message #26956] Tue, 21 December 2004 04:37 Go to previous messageGo to previous message
I'm looking forward to it!
Previous Topic: concert series JBLs 8 pin connection
Next Topic: Marshall modification
Current Time: Wed May 08 15:44:44 CDT 2024
