Home » Audio » General » One last computer question, I promise
One last computer question, I promise [message #2626] Sun, 08 January 2006 07:09 Go to next message
Gonna definitely wipe the HD and start over.
Thanks to all for your suggestions.
Question: how can I know if the documents I save, fotos, pdf's, favorite lits, etc., are clean or infected with whatever is causing the trouble?
Re: One last computer question, I promise [message #2627 is a reply to message #2626] Mon, 09 January 2006 08:37 Go to previous messageGo to next message
The adware/spyware/virus detection programs can be used to investigate your data files. Copy them onto CD before formattting your hard drive, then check install the OS and virus detection program. Run the scan on the CD before copying it onto your hard drive. That will tell you if you have problems before you get everything loaded.
Re: Sounds like a plan; I found the problem, I think [message #2628 is a reply to message #2627] Mon, 09 January 2006 18:15 Go to previous messageGo to next message
My son-in-law suggested I try XoftSpy. Free download. Sorta!
It found something called worm.p2p.tanked
And that my search bar had been "hijacked"
So it has the usual checkboxes and "remove" clickbox........
Which asks that you register........OK............
Pay $40 to register!
No pay, No play
$40 is fair but doesn't that sound like blackmail or piracy or baratry (love that word) or something?
Re: Sounds like a plan; I found the problem, I think [message #2629 is a reply to message #2628] Mon, 09 January 2006 23:02 Go to previous messageGo to next message
before you give up. make a copy of all your files you want to keep.
then take a look in the windows folders, temp folders, and programs files. there is are exe files in there that you have to manually delete. if, you delete the wrong files, you just entered reformat land! I cant even begin to explain which ones are keepers and which ones are problems. if your looking at fdisk then why not take a learn.
try this place. follow the instructions. if might help you out. all the stuff is free.
http://securitytango.com/
anyone tried linux lately?
Re: Sounds like a plan; I found the problem, I think [message #2631 is a reply to message #2628] Tue, 10 January 2006 08:47 Go to previous messageGo to next message
You might try the free McAfee program at the post below:
Maybe that will get it. If not, here are a few websites about your virus. One of them certainly must have a freeware removal program or manual removal instructions.
Re: Sounds like a plan; I found the problem, I think [message #2632 is a reply to message #2629] Tue, 10 January 2006 14:31 Go to previous message
lon is currently offline  lon
The Security Tango link looked to be a good one.
I'm always trying Linux.
I'm in the not-trying mode at the moment until I read further
on using the Samba networking system in a Dummies(c) book.
Sooner or later there will be a version that anyone can use.
My latest project is seeing whether Edubuntu is the right
choice for a family that has one current generation HP
PC running XP with an SBC dsl line and an old beater
handme down to be used by a youngster who is 8.
Latest tip on easy installs for general use is Mandriva. I
personally don't know what's so good about it, but I've got
some iso files to eventually install that as well.
The Ubuntu releases have names like hoary hedgehog, and
dapper drake (for the Linux mascot.) I'm waiting for the
release called Happy Camper. Ha ha.
Previous Topic: Penn and Teller
Next Topic: Great Plains Audiofest 2006
Current Time: Tue May 14 15:21:44 CDT 2024
