Home » Audio » Speaker » Acoustats bias must be 5k for the panels,now 3k750 get 5db more output
Acoustats bias must be 5k for the panels,now 3k750 get 5db more output [message #24783] Sat, 06 October 2007 06:42 Go to next message
tubevibb is currently offline  tubevibb
Amps ON FIRE,hard to drive, need the right Amp well not work in some rooms?
Well if you have stock Bias, you are down low
my Stock Bias was only 3k,two more diods an two more caps an now thay sound like silk, amp runs cool be for to hot to touch.get 5db
it even call for 5k on the bord.not even close
Bias xformers sec. ac is 750ac 5 diods 3k750??????????
an now you have lose on the 500m you end up 3k maybe
two more diods an tow more caps now get somewere
thanks
Allen
Re: Acoustats bias must be 5k for the panels,now 3k750 get 5db more output [message #24784 is a reply to message #24783] Sun, 07 October 2007 11:21 Go to previous message
Good info, thanks!
Previous Topic: What glue?
Next Topic: For those who have bought the DCA 5.5 M drivers
Current Time: Sun May 12 21:08:45 CDT 2024
