Home » Audio » Speaker » how to check for this
how to check for this [message #23186 is a reply to message #23183] Wed, 13 September 2006 18:20 Go to next message
lcholke is currently offline  lcholke
Hi Jose,
I would like to check for this without damaging the ribbons on the array I have. What was your method.
-Linc
Re: Phase problem with Fountek ribbin tweeter [message #23188 is a reply to message #23183] Thu, 14 September 2006 16:16 Go to previous messageGo to next message
Rick Craig is currently offline  Rick Craig
I've tested quite a few of the Founteks and never had this problem.
Re: how to check for this [message #23189 is a reply to message #23186] Thu, 14 September 2006 16:18 Go to previous messageGo to next message
The only reliable way is to run an impulse response with measurement equipment.
Re: how to check for this [message #23190 is a reply to message #23187] Thu, 14 September 2006 16:20 Go to previous message
NEVER use a battery to test the polarity of a true ribbon! You can damage the ribbon element.
Previous Topic: Just built an attic subwoofer...
Next Topic: What happens to T/S for dual horn drivers?
Current Time: Tue May 14 17:05:35 CDT 2024
