Home » Audio » Speaker » Macintosh box modeling software, or suggestions for . . .
Macintosh box modeling software, or suggestions for . . . [message #18791] Wed, 05 July 2006 09:35 Go to next message
DRC is currently offline  DRC
Hi Guys,
I've still got the Martinelli maple horns with TAD2001 drivers attached, can't bear to sell them, and I'm now looking to build a two way, crossing the TAD over at the min. 800hz. Like to stay low order xo, not worried about power as I'm using the Yamamoto A08 45 amp.
Very interested in the hemp drivers for the bottom, but I don't know of any Mac-compatible box software, and I'm not finding response curves, so I'm at somewhat of a loss . . .
I'm eyeing the Tone Tubby 10" SuperBoy, (designed for electric bass), whose specs are as follows:
Driver Properties
Name: TT Bass 10
Type: Standard one-way driver
Fs = 63.8 Hz
Fsa = 42.7 Hz
BWs = 81.4 Hz
Vas = 48.4 Liters
Cms = 2.82E-04 m/N
Mmd = 18.3 g
MMr = 3.76 g
BL = 11.1 Tesla/m
Eta = 2.61 %
Qms = 1.69
Qes = 0.46
Qts = 0.36
Re = 6.400 Ohms
Zmaxs = 29.7 Ohms
2.83-V SPL = 97.1 dB
1-W SPL = 96.2 dB
Kr = 0.000
Xr = 0.000
Ki = 0.000
Xi = 0.000
Anythoughts, suggestions guys? TIA !
Re: Macintosh box modeling software, or suggestions for . . . [message #18792 is a reply to message #18791] Wed, 05 July 2006 18:53 Go to previous messageGo to next message
Okay, I've found MacSpeakerz, but it's written to operate under OS9. OS9?! Maaannn, that's a blast from the past. I didn't install it under my OS10.4 deliberately because Classic mode caused me nothing but grief in earlier iterations.
Grumble, grumble . . .
Re: Macintosh box modeling software, or suggestions for . . . [message #18793 is a reply to message #18792] Wed, 05 July 2006 23:47 Go to previous messageGo to next message
I know it's heresy, but maybe a PC emulator would be the easy way out? Is there one available that will run Boxplot? That should do the trick. You can also run PiAlign pretty easily 'cause it's an old DOS program. But PiAlign only makes cabinet recommendations whereas Boxplot actually calculates response.
Re: Macintosh box modeling software, or suggestions for . . . [message #18794 is a reply to message #18792] Fri, 07 July 2006 20:41 Go to previous messageGo to next message
More bad news, Macspeakerz doesn't plan to do another release. Rats.
Re: Macintosh box modeling software, or suggestions for . . . [message #18795 is a reply to message #18793] Fri, 07 July 2006 20:43 Go to previous messageGo to next message
A couple hundred dollar outlay to run a piece of shareware doesn't sound terribly appealing, I must say.
The newest Macs can run Windows directly, but I won't be in the market (again) for a couple more years, I don't think.
I could always download it and run it on my son's PC. That's probably the easiest thing to do. Shoulda thoughta that before. . . .
Re: Macintosh box modeling software, or suggestions for . . . [message #18796 is a reply to message #18795] Sat, 08 July 2006 11:25 Go to previous messageGo to next message
There are open source PC emulators out there, so you might look into one of those.
Re: Macintosh box modeling software, or suggestions for . . . [message #18797 is a reply to message #18791] Sat, 08 July 2006 15:44 Go to previous message
WinISD is available on-line (java script)
Previous Topic: Line Array versus Point Source Kits
Next Topic: Ultimate Line Array ($?)
Current Time: Mon Apr 29 00:12:28 CDT 2024
