Home » Audio » Speaker » Corner Placement: In or Out?
Corner Placement: In or Out? [message #16749] Tue, 27 July 2004 13:29 Go to next message
What's the difference between having the woofer face into a corner vs away from a corner in a corner placement speaker, for the purpose of increasing sensitivity?
Gar.
Re: Corner Placement: In or Out? [message #16750 is a reply to message #16749] Tue, 27 July 2004 13:54 Go to previous messageGo to next message
It depends on the distance and the frequencies of interest. If the radiator is within a quarter wavelength, it doesn't really matter. But if it's further than that, the walls act as reflectors.
Does this mean ... [message #16751 is a reply to message #16750] Tue, 27 July 2004 14:34 Go to previous messageGo to next message
that facing into the corner can potentially place the driver closer, and therefore, increasing the effective bandwidth that the corner has an impact on SPL?
Re: Does this mean ... [message #16752 is a reply to message #16751] Tue, 27 July 2004 15:45 Go to previous message
Yes, if you can get the radiator closer into the corner, it will be effective at higher frequency. The further out you move it, the lower the point at which boundaries begin to act like reflectors. It's the same sort of thing that happens at the baffle step transition.
Previous Topic: LA HF horns
Next Topic: You know what phrase I hate the most in speaker ads?
Current Time: Sat May 11 02:29:02 CDT 2024
