Home » Audio » Speaker » ALE, Goto, Oris
ALE, Goto, Oris [message #16421] Mon, 03 May 2004 05:19 Go to next message
Bradford is currently offline  Bradford
Without regard to size or cost, which is better, Goto or ALE? What horn design(s) are best for these drivers and how do they compare with a Lowther horn like Oris?
Re: ALE, Goto, Oris [message #16423 is a reply to message #16421] Mon, 03 May 2004 11:56 Go to previous messageGo to next message
Ale and Goto make compression drivers and the Lowther is a cone driver. There are some similarities, in that both have diaphragms that are driven by a voice coil. But diaphragm material, suspension and thrust point are different. Cone drivers generally have greater surface area and compression drivers are built so they can withstand higher pressure.
Re: ALE, Goto, Oris [message #16562 is a reply to message #16421] Fri, 28 May 2004 10:01 Go to previous messageGo to next message
W.Burkhardt is currently offline  W.Burkhardt
Hallo,
do you want some information about Goto´s.
I have a full 4way-System from Goto.
regards walter
Re: ALE, Goto, Oris [message #16575 is a reply to message #16562] Wed, 02 June 2004 10:48 Go to previous message
Do you have a photograph on a website that you could post here?
Previous Topic: Ever wonder how the White Van's Measure?
Next Topic: Hey Graeme!
Current Time: Mon May 20 18:36:58 CDT 2024
