Home » Audio » Speaker » I did it ! What did I do???
I did it ! What did I do??? [message #16011] Sat, 10 January 2004 12:19 Go to next message
Well, as of this morning I have my system flat, + / - 3dB from 30 Hz to 16 Khz at the listening position.
I'm not impressed by the sound, though. I think I liked it better when I had it balanced by ear.
Am I unable to appreciate proper response, or is flat not as desirable as I thought it was supposed to be?
Re: I did it ! What did I do??? [message #16013 is a reply to message #16011] Sat, 10 January 2004 18:05 Go to previous messageGo to next message
GraemeG is currently offline  GraemeG
I have often wondered why so much effort is put into achieving dead flat response. Our ears' response isn't flat and varies between individuals anyway. I consider the ear to be more like a musical instrument than a measuring device - the best system is the one which is most pleasing to YOUR ear, not the one that measures flattest.
Cheers
Re: I did it ! What did I do??? [message #16014 is a reply to message #16011] Sun, 11 January 2004 08:14 Go to previous messageGo to next message
Thats funny. I have spent long periods of time geting a system perfectly flat. Didnt sound good to me either. Any of the times I did it! I was also told by some sound engineers I wouldnt like it either. I always thought the good studio monitors had a very flat response, and for that reason most people never liked them as a hi-fi speaker.
Bill
Re: I did it ! What did I do??? [message #16018 is a reply to message #16011] Mon, 12 January 2004 10:00 Go to previous messageGo to next message
I used to work in a recording studio part time years ago, and I found it takes time to get your ears listening to a system with a totally flat response, but once you get used to it, it's not so bad you can really tell on other systems that have just the BOOM and HISS to them and no mids detail. On my home system, my systems ran flat with maybe 3-6db boost on the lower freq (40-70hz) and it sounds good at least to me anyway. But for home let your ears be your guide on what sounds best to you, those are your built in insturments.
Re: I did it ! What did I do??? [message #16019 is a reply to message #16011] Mon, 12 January 2004 21:26 Go to previous messageGo to next message
In my opinion, it's not as important if you have flat response or not, as it is how you achieved that flat response. If you made aterations to the speakers or the signal that causes phase problems or dynamics problems, you may have lost more then you gained in achieving that flat response. There are other things that can affect the music more then not having a perfectly flat responce, IMHO.
Dave :^)
Give it some time??? [message #16023 is a reply to message #16011] Tue, 13 January 2004 09:01 Go to previous messageGo to next message
Also
FR,is just one of the many things to measure
now that you have a great flat response
why not listen to a fullrange speaker that people love,and compare it.simplicity no x over,see if it appeals
A moderately flat response i want,but i dont want to sacrifice other things to get that.
The listening room affects so much..
Its interesting to hear...
I plan on building a horn system in the future ,, up to 16khz like adrian macks.
Cheers!!
Bit of of an update [message #16024 is a reply to message #16011] Tue, 13 January 2004 22:11 Go to previous message
After a couple of days I find that from the midrange up I like things a lot better, more balanced, more "articulate".
I've also been tweaking away so I now have +/- 1 dB. There's a big peak at 125 Hz, so I'm going to fool with the first XO point (now approximately 150 Hz) to see if I can reduce the amount of EQ necessary there.
I'm beginning to think that flat may be right for reproduction (as opposed to reinforcement) because the producer has EQ'd the recording so that it expresses what he intended. Maybe trying to improve on the recording by adding boost or cut where I'd like it to be is the wrong approach.
Previous Topic: New Speaker
Next Topic: Whiteley Stentorian HF-1012's
Current Time: Fri May 10 10:45:27 CDT 2024
