Open Baffle Bass - Why Not ? [message #15987] |
Sun, 04 January 2004 12:26 |
wunhuanglo
Messages: 912 Registered: May 2009
Illuminati (2nd Degree) |
Has anybody here experimented with open baffle/dipole bass? I'm kind of intrigued because, from what I understand, very good quality can be achieved with what is obviously simple construction. There are many car audio woofers with low Fs, high Qts and large Xmax ratings that would seem to be tailor made to EQ at the bottom. And given their 4 ohm impedance, they’d be simple to wire in series for an 8 ohm load. Bad idea?
Re: Open Baffle Bass - Why Not ? [message #15988 is a reply to message #15987] |
Sun, 04 January 2004 14:46 |
hurdy_gurdyman
Messages: 416 Registered: May 2009
Illuminati (1st Degree) |
I've been using OB for bass for about a year now. It's the cleanest bass I've ever had in my house. Like all other types of bass cabnets, it has advantages and disadvantages. The biggest advantage, to me, is the figure 8 response pattern. Energy to the sides of the baffle is neatly canceled out. There is much less room activated bass, thus the bass coming from your speaker is what you hear, not a lot or reenforcement and cancellation waves. Also, lack of box resonance is nice. Disadvantages include lack of efficiency. It takes either more power or more drivers to get loud and deep. My OB's work well in the corners, so they don't take up a lot of room space. Dave
Hi Dave [message #15989 is a reply to message #15988] |
Sun, 04 January 2004 15:30 |
wunhuanglo
What sort of power are you talking about? I saw on your site that you use a Citation 16? Charlie
Re: Hi Dave [message #15990 is a reply to message #15989] |
Sun, 04 January 2004 15:37 |
hurdy_gurdyman
The harman-kardon citation 16 puts out a clean 240 watts a channel into 4 Ohms. It goes into clipping about the same time as my 20 watt per channel Scott tube amp driving my Heresy's. The Heresy's are fairly efficient, the subs can't come close in efficiency. The resulting sound is great, though, so I can live with the efficiency difference. The gap in efficiency will narrow as more OB drivers are added (future project). Dave :^)
Re: Check out Linkwitz [message #15991 is a reply to message #15987] |
Sun, 04 January 2004 18:11 |
Bill Martinelli
Messages: 677 Registered: May 2009
Hi Charlie,Take a look at Linkwitz site if you havnt already. Wayne and I talked about a dipole bass box for a while but never got it off the ground. The basic idea, and exagerated for this discussion. You can use two 25 dollar woofers and have high efficiency and very low distorion as you would expect from a 300 dollar woofer. Linkwitz has some dimensions and instructions for a few of these last I saw. Bill Love your VOTT's too
Re: Check out Linkwitz [message #15992 is a reply to message #15991] |
Sun, 04 January 2004 19:05 |
wunhuanglo
Thanks, Bill. I've given his Orion a cursory look in the past. Truthfully, I was trying to stimulate some conversation among people who "don't have a dog in the fight". Also, for a dummy like me picking out the bottom-line from SL’s expositions is more than a bit difficult (I guess I lack sufficient will). What sort of arrangements did you and Wayne discuss? Charlie
Re: Check out Linkwitz [message #15993 is a reply to message #15992] |
Sun, 04 January 2004 22:01 |
Bill Martinelli
The Di pole design cuts back on second harmonic distortion primarily. I'm not an expert in these regards so for the hard dry facts you need to work with the pocket protecters! As always theres no free lunch, meaning your not going to get 30hz, 100db and 1 cubic foot all in the same speaker. Like I said the biggest advantage here is to get very low distortion using 'lesser' quality drivers that would cost a fraction of a single 'good' driver. It also seems possible to have a little more bottom end from this arrangment too. The best bang for the buck drivers that came to mind would be an Eminance Delta12LF. There are some Pioneer drivers I have used in 10" that are in th 20 -30 range. These would also be great drivers. The feelings I got from poking around would be to slot load the drivers. With the two driver facing each other and a slot for an opening. This could be just a simple bottom section to a cabinet with a mid and horn built into the top. Like your jbl driver on the VOT. You can even corner load the slot for room boundry gains. Olsen did some work with two driver in a few different arrangements. This is similar to Isobaric, but perhaps not in the true sense. Again, more of an engineers reference in needed here. This sure isnt anything new. Actually, it's all been done before! Just another version as we move on. I dont have any thing on paper that you can build from. If memory serves There are drawings and dimensions around at a few places and the dimensions can be changed for the spec on the drivers your using. Bill
Re: Check out Linkwitz [message #15994 is a reply to message #15993] |
Sun, 04 January 2004 22:21 |
Messages: 18686 Registered: January 2001
It's the push-pull configuration that reduces second harmonics, not a single driver dipole. The idea is that if there is uniform asymmetrical motion from the suspension or the motor, driving two similar devices in opposite directions will cancel it. The dipole configuration has a lot of advantages, directivity being one of its biggest. But I wasn't planning to use this arrangement. I was considering the use of a push-pull driver configuration in a π cornerhorn. It would use a ported motor chamber and not a dipole. Just thought I'd clarify.
why not! [message #15996 is a reply to message #15987] |
Tue, 06 January 2004 08:36 |
Mike.e
Messages: 471 Registered: May 2009
There are many car audio woofers with low Fs, high Qts and large Xmax ratings that would seem to be tailor made to EQ at the bottom. And given their 4 ohm impedance, they’d be simple to wire in series for an 8 ohm load. I know one has to buy Car audio generally-i notice many kicker brand subs have super high Qts the dayton 15" IB woofer comes to mind, 109$ on special lastweek i saw...... i like high SPL though,like 115db at listening position,so IB doesnt appeal to me at the moment.but if i have my horn subs for high output,i would like to try this dipole idea Smaller box too! :-)
