Home » Audio » Source » Tascam 133
Tascam 133 [message #13835] Mon, 29 August 2005 07:50 Go to next message
Rick Mason is currently offline  Rick Mason
Hi
I got two Tascams 133's but both need the main drive belts replacing. Is this hard? Can you do it without removing loads of parts? Is there a service manual showing you how?
cheers
Rick
Re: Tascam 133 [message #13836 is a reply to message #13835] Mon, 29 August 2005 15:40 Go to previous messageGo to next message
Check StereoManuals.com.
Re: Tascam 133 [message #13858 is a reply to message #13835] Fri, 17 February 2006 13:23 Go to previous messageGo to next message
Just happened to notice this. I've changed the belts in three of these. Just requires patience, nothing too hard.
Dave
Re: Tascam 133 [message #13910 is a reply to message #13835] Thu, 29 March 2007 01:53 Go to previous messageGo to next message
cheers thanks for that. do you know where I can find the belt?
Re: Tascam 133 [message #13956 is a reply to message #13858] Sat, 11 August 2007 01:30 Go to previous message
Jan is currently offline  Jan
I have bought a replacement belt for the Tascam 133, as the old one broke. I cannot figure out how to replace it, as there are many components in the way. Can one replace the belt without removing parts from the deck? Is there a "smart" way of doing this?
Regards
Jan
Previous Topic: Beginner looking for an Ideal turntable to buy need help please reply
Next Topic: Replacing belt on Tascam 133
Current Time: Sat May 11 06:42:20 CDT 2024
