Home » Audio » Source » Rek-O-Kut project finished at last!
Re: Rek-O-Kut project finished at last! [message #13476 is a reply to message #13475] Wed, 22 August 2007 13:52 Go to previous messageGo to next message
That should have stated above that the mat was from a DP-75, not a TP-75. Brain fart...
Dave
Re: Rek-O-Kut project finished at last! [message #13497 is a reply to message #13441] Fri, 31 August 2007 08:56 Go to previous messageGo to next message
Just wanted to post that my Yahoo photos of the Rek-O-Kut project has been moved to Flickr.
http://www.flickr.com/photos/12271467@N03/sets/72157601762905060/
Dave
Re: Rek-O-Kut project finished at last!--The O-Ring Idler [message #13500 is a reply to message #13441] Sat, 01 September 2007 16:35 Go to previous messageGo to next message
David Lawrence is currently offline  David Lawrence
Hi,
Could you say anything about how you had this made? Was it a modification of a ready-made idler pulley? Did you use a sintered bronze bearing or a bushing below? What size and thickness of o-ring did you use? How much did the machine shop charge? Thanks a lot for any advice.
David
Re: Rek-O-Kut project finished at last!--The O-Ring Idler [message #13502 is a reply to message #13500] Sat, 01 September 2007 20:03 Go to previous messageGo to next message
>Hi,
David
Re: Rek-O-Kut project finished at last!--The O-Ring Idler [message #13503 is a reply to message #13502] Sat, 01 September 2007 21:11 Go to previous message
Thanks a lot Dave. That will be helpful.
David
Previous Topic: Phono Cartridge
Next Topic: two funny sl-d2's in a row?
Current Time: Mon May 06 06:54:40 CDT 2024
