Home » Audio » Source » need some advice
need some advice [message #13477] Thu, 23 August 2007 08:23 Go to next message
nikolaos is currently offline  nikolaos
Hi all,
It is time for me to get a decent turntable and start buying LPs. My budget will be around 300-500$. Can you please let me know your suggestions? I am pretty clueless so any help will be appreciated
Thank you
nikolaos
Re: need some advice [message #13478 is a reply to message #13477] Thu, 23 August 2007 20:37 Go to previous messageGo to next message
I've never seen a table on Audiogon in your range that could exceed a new Technics 1200. One from Musicians Friend and a $100 cart like AT440 would be an excellent set-up.
A great upgrade path exists for the table with the damping trough from KABUSA as funds allow. Then perhaps a used Grado Sonata.
You can read my short article on tweaking the suspension farther down the road.
Re: need some advice [message #13479 is a reply to message #13478] Fri, 24 August 2007 08:46 Go to previous messageGo to next message
I second Bill's suggestion to go with a Technics 1200 for that price range.
Re: need some advice [message #13515 is a reply to message #13477] Tue, 18 September 2007 13:34 Go to previous messageGo to next message
willyable is currently offline  willyable
This is what I can offer you go to www.needledoctor.com. They have a bunch of turntables you can take a look at and I'm sure you will find what you want.
Re: need some advice [message #13532 is a reply to message #13477] Fri, 28 September 2007 19:11 Go to previous messageGo to next message
Listens2tubes is currently offline  Listens2tubes
You can find a Systemdek IIX in the $300-$400 range.
Re: need some advice [message #13533 is a reply to message #13479] Tue, 02 October 2007 10:46 Go to previous message
Crystal is currently offline  Crystal
Where is the best place to get a technic 1200 from?
Previous Topic: PLEASE HELP! JVC L-A55 and Harmon Kardon 720
Next Topic: what's this turntable type
Current Time: Mon Apr 29 01:41:46 CDT 2024
