Home » Audio » Source » Rek-O-Kut project finished at last!
Rek-O-Kut project finished at last! [message #13441] Fri, 20 July 2007 18:29 Go to next message
After many months of work and waiting, my Rek-O-Kut with Infinity Black Widow/Grado Blue is finally finished! Here's a link to some pics.
http://www.hawthorneaudio.com/photos/thumbnails.php?album=34
I'm very happy with how this turned out.
Dave
Re: Rek-O-Kut project finished at last! [message #13442 is a reply to message #13441] Sat, 21 July 2007 19:08 Go to previous messageGo to next message
Outstanding! Love the frame.
How does it sound?
Re: Rek-O-Kut project finished at last! [message #13443 is a reply to message #13442] Sat, 21 July 2007 20:10 Go to previous messageGo to next message
>How does it sound?
Re: Rek-O-Kut project finished at last! [message #13445 is a reply to message #13443] Mon, 23 July 2007 08:21 Go to previous messageGo to next message
Wow! That looks awesome, Dave! Is the aluminum plate mounted on rubber or it is firmly attached to the base?
Re: Rek-O-Kut project finished at last! [message #13447 is a reply to message #13445] Mon, 23 July 2007 08:33 Go to previous messageGo to next message
Re: Rek-O-Kut project finished at last! [message #13449 is a reply to message #13447] Mon, 23 July 2007 17:58 Go to previous messageGo to next message
I see. I was just trying to visualize how it was mounted. Sounds good!
Re: Rek-O-Kut project finished at last! [message #13456 is a reply to message #13449] Wed, 25 July 2007 01:00 Go to previous messageGo to next message
Wayne,
As an experiment, I removed the rubber weatherstripping completely and screwed down the chassis to the plinth directly. Using a stethoscope, there is a very noticeable drop in noise, from quiet to very quiet.I'm going to leave it this way.
Dave
Re: Rek-O-Kut project finished at last! [message #13459 is a reply to message #13456] Wed, 25 July 2007 16:25 Go to previous messageGo to next message
Very interesting. It's almost like mechanical grounding verses floating, isolated. Interesting.
Re: Rek-O-Kut project finished at last! [message #13474 is a reply to message #13441] Wed, 22 August 2007 10:25 Go to previous messageGo to next message
David Lawrence is currently offline  David Lawrence
That looks great.
Is the plinth contacting the plate around the bearing? Was it difficult to adjust the levels of the plinth to the different thicknesses of the Rek-O-Kut plate?
What kind of record mat are you using?
David
Re: Rek-O-Kut project finished at last! [message #13475 is a reply to message #13474] Wed, 22 August 2007 13:50 Go to previous messageGo to previous message
David,
>Is the plinth contacting the plate around the bearing?Was it difficult to adjust the levels of the plinth to the different thicknesses of the Rek-O-Kut plate?What kind of record mat are you using?
Previous Topic: Phono Cartridge
Next Topic: two funny sl-d2's in a row?
Current Time: Sun Apr 28 00:12:32 CDT 2024
