Home » Audio » Source » Sony PS-LX250H Turntable, Auto mechanism problem
Sony PS-LX250H Turntable, Auto mechanism problem [message #12023] Mon, 28 March 2005 04:41 Go to next message
bpage is currently offline  bpage
Hello , i've recently bought a the PS-LX250H turntable from Sony, and the playing of records is just fine except for one problem... When pressing the "start" button to auto-play a record, the arm lifts, slides to the record, puts the stylus down normally, but 2 secs later, it picks up the stylus, and gets back into the off position and the turntalbe stops. What could be wrong?
Thanks
B. Page
Re: Sony PS-LX250H Turntable, Auto mechanism problem [message #12025 is a reply to message #12023] Mon, 28 March 2005 06:07 Go to previous messageGo to next message
You need to open the table and look underneath. There are two arms and a pair of gears that move the arm. When the arm stops too soon it is most liklely that one of the gears is either mis-aligned or the rubber band that puts tension on the rotating gear arm is worn out.
You can play with it but it probably needs someone who does this.
Re: Sony PS-LX250H Turntable, Auto mechanism problem [message #12031 is a reply to message #12025] Tue, 29 March 2005 06:34 Go to previous message
thanks manualblock, ill try tonight
Previous Topic: Rega belts
Next Topic: Just upgraded my source to older hi-fi: Museatex By Ed Meitner
Current Time: Mon May 06 16:53:48 CDT 2024
