Home » Audio » Thermionic Emissions » Hybrid SET question
Hybrid SET question [message #11378] Mon, 14 May 2007 13:26 Go to next message
TampaTubes is currently offline  TampaTubes
This maybe a really stupid question but what the hell. In the interest of open minded experimentation, is it possible to use an IC like the LM4562 as the input/driver of a 2 stage SET amp? Anything from a relatively easy load like a 6bq5 to a 300B or 845, whatever?
Re: Hybrid SET question [message #11379 is a reply to message #11378] Wed, 16 May 2007 11:21 Go to previous messageGo to next message
If you think about it, this is pretty much what tubed DACs do. Some take the op-amps out and drive the tube directly from the DAC, but you still have solid state driving tubes. Even if just a ladder voltage divider, it's still sand driving tubes. I'd say give it a go and see how it sounds!
Re: Hybrid SET question [message #11381 is a reply to message #11378] Thu, 19 July 2007 06:57 Go to previous message
I'm thinking that the max rail voltages of +/- 17v might limit you to easy tubes like EL84,EL34. Otherwise you might need an additional gain stage. The swing needed for a 300b is pretty healthy, and an 845 much more so. Still, no reason it couldn't be used as a 1st stage in a 3 stage design. I'm not any kind of expert on this, so maybe someone else will chime in.
Previous Topic: Tweaking the ARC LS-1
Next Topic: fender hot rod series combo amp ques.
Current Time: Sat Apr 27 12:02:20 CDT 2024
