Home » Audio » Thermionic Emissions » Tube amp humm, Power conditioner?
Tube amp humm, Power conditioner? [message #11293] Mon, 27 February 2006 18:31 Go to next message
Peter Swartz is currently offline  Peter Swartz
Hello, I'm concidering purchasing a power conditioner to help clean up some of my amp humm and noise. Is it likely that this would help? Can you suggest a specific type? I don't want to accidentally buy a high dollar power strip. What type of components should I be looking for? How much should I expect to spend? Can a couple hundred dollars do the trick? Thanks for your help, Pete
Re: Tube amp humm, Power conditioner? [message #11294 is a reply to message #11293] Mon, 27 February 2006 18:55 Go to previous messageGo to next message
I think it is not a good idea. Think in terms of what a power conditioner does; it prevents overloads and controls the release of power to the amp during times of high demand. Exactly what you don't want.
Re: Tube amp humm, Power conditioner? [message #11298 is a reply to message #11293] Wed, 01 March 2006 20:28 Go to previous messageGo to next message
You just missed the steal of the century. Picked this up for $120, after $50 rebate. Too bad the sale has ended. Not sure it would help with your hum, but it didn't break the bank and looks a hella lot cooler than my Topaz power conditioners........Colin
Hum or Noise? [message #11303 is a reply to message #11293] Fri, 03 March 2006 07:27 Go to previous messageGo to next message
Peter,
Are you having problems with hum or noise? If hum, the most common cause of it is ground loop and a power conditioner wouldn't help.
Re: Tube amp humm, Power conditioner? [message #11347 is a reply to message #11298] Thu, 10 August 2006 23:52 Go to previous message
John Chleapas is currently offline  John Chleapas
Just a thought. I do not think Monster unit this is a surge protector, or has filtering also does it? For about $150 you can buy a used Powervar hospital lab grade with voltage and line filtering on ebay. I have two Powervars now and a third one for my home theater coming. These filter and offer excellent protection since they were designed for high end sensitive laboratory equipment. These Powervars still sell new for ~$1200 for the model 12 that I have. They are a steal at around $200 used. For my audio system I added an additional level of dedicated line filtering for my two pairs of tube mono block amps into these Powervars. The background noise level dropped down to next to nothing. I have very sensitive 6' tall 2-way horn speakers at over 100dB efficient with 1 Watt at 1 Meter. Just another suggestion is all. John
Previous Topic: New Transformer
Next Topic: Say John 42
Current Time: Fri Apr 19 07:59:29 CDT 2024
