Home » Audio » Thermionic Emissions » Kt-88
Kt-88 [message #10743] Mon, 04 October 2004 16:55 Go to next message
Missed the post on dual-mono Russell. What I have for trannies is the Handwound replacements they build for the Dyna ST-70. The specs are similar but the build is better. They can run EL-34's or KT-88's 6550's etc. The plitron Iron is they way to go. What I was thinking was to build with the handwound then substitute when funds permit. The circuit seems adaptable to either or. J.R.
Bias [message #10748 is a reply to message #10743] Wed, 06 October 2004 20:50 Go to previous messageGo to next message
J.R.
I got my copy of VTV 19 (and 18 and 17) and had a chance to review the KT88 design. One question for you. What are you suppose to bias the tubes at with the bias setting?
Gar.
Re: Bias [message #10749 is a reply to message #10748] Thu, 07 October 2004 07:01 Go to previous messageGo to next message
Hi Garman; I am not sure what you mean. I believe it is set at -62v. Is that what you get? J.R.
Re: Bias [message #10753 is a reply to message #10749] Mon, 11 October 2004 16:37 Go to previous messageGo to next message
I was just confused as to what the bias metre should read with the adjustment of the two 10K bias pots. Gar.
Re: Bias [message #10755 is a reply to message #10753] Mon, 11 October 2004 19:52 Go to previous messageGo to next message
I wonder if it would be possible to model it with Circuitmaker?
Re: Kt-88 [message #10758 is a reply to message #10743] Wed, 13 October 2004 17:21 Go to previous message
I sort of had the same idea. plitron is the bees knees, but thats a lot of expensive iron if one goes it all at once. Russellc
Previous Topic: KT-88 continued
Next Topic: tone controls
Current Time: Thu May 09 22:25:56 CDT 2024
