homebrew [message #10736] |
Wed, 29 September 2004 21:33 |
hollister
Messages: 1 Registered: May 2009
Esquire |
whose building homebrews here? im kinda looking for ideas on whats kickin.
Re: homebrew [message #10740 is a reply to message #10739] |
Thu, 30 September 2004 20:51 |
Messages: 18688 Registered: January 2001
Hi John, Which VTV amp? I probably should know - You've probably mentioned it. But refresh my memory. Is it one of the circuits in a back issue of Vacuum Tube Valley magazine? Speaking of, I wonder where Eric has gotten off to. Wayne
Re: homebrew [message #10741 is a reply to message #10739] |
Fri, 01 October 2004 07:42 |
GarMan
Messages: 960 Registered: May 2009
Illuminati (2nd Degree) |
Cool. That's the same design Eric recommended to me when I was looking for an amp with "balls". Keep us up to date on this. thanks, Gar.
Re: homebrew [message #10742 is a reply to message #10739] |
Mon, 04 October 2004 07:09 |
Russellc
Messages: 397 Registered: May 2009
Illuminati (1st Degree) |
No problem, manualblock. I did the same when I built my KT 88 amp. It was the rosenblitz design intended for mono blocks. Just configure it with a single power x-former with twice the milliamperage ( is that a word?), and make it dual channel, (two sets of rectifiers, etc) after the x-former. The only difference is how the transformer hooks to the rest of it I put the power supply in a separate chassis. In the amp chassis, it is true dual mono..you could saw this in half with a hacksaw and it would be mono block. If I had it to do over, I would seriously consider building it all on one chassis for simplicity. the amp is on a 17x15 and the power supply on a 10x17. If you are building the VTV amp, are you using the plitron Iron? Even the coils are quite pricey. I thought of building it using the plitron outputs, but cheaping out on the coils and maybe the power trans. Hope this helps Russellc
Hope this helps, Russellc
Re: homebrew [message #10778 is a reply to message #10737] |
Mon, 01 November 2004 23:23 |
Norris Wilson
Messages: 361 Registered: May 2009
Grand Master |
Hi Manualblock, If my memeory seves me correcty, I believe that this is basically the same circuit as the VTV KT-88 amplifier, it has been a while since I have seeen it, my memeory is short. Would you please guide me to the VTV schematic on line if possible, so I can compare the two circuits? I have a pair of the Allen amplifiers and want to see if the VTV circuit would give me any pointers in upgrading what I have. Thanks Norris Wilson
Re: homebrew [message #10875 is a reply to message #10736] |
Wed, 15 December 2004 22:36 |
colinhester
Messages: 1349 Registered: May 2009 Location: NE Arkansas
Illuminati (3rd Degree) |
Hollister, Check out latest thread on ART's SET forum for a group build. A couple of us having been kicking around the idea of building a tube preamp. Would love to see you there.....Colin Hester
