cheap kits for tube amps [message #10510] |
Thu, 15 January 2004 08:00 |
Manualblock
Messages: 4973 Registered: May 2009
Illuminati (13th Degree) |
Try "Gabes Tube Amplifiers and Stuff", he makes a SE 6watt from a 6sl7 tube rectified for 549$ and a 300b with tubes SE for 700$ as well as some pre-amps etc. interesting.
Re: cheap kits for tube amps [message #10513 is a reply to message #10512] |
Thu, 15 January 2004 14:13 |
Messages: 18688 Registered: January 2001
This one? I saw that, and it looked real nice. Clean look, and from the description it sounds like it probably works well. For $550.00 for the kit, a person sure can't get hurt to give it a try! I'll definitely check that one out, when the schedule permits. I'm still waiting for my Seduction kit, and I've got a "to-do" list about two years long. But that 606 kit sure looks interesting...
Re: cheap kits for tube amps [message #10514 is a reply to message #10513] |
Thu, 15 January 2004 15:07 |
Manualblock
That looks like it but if you look under the projects page listing for "real simple and cheap 45/2a3 set", he gives an account of the design process that might have been an ealier iteration of that amp. There is a sidebar within that tutorial called 6L6 SE, just click on that. Very good info for begginners anyone reading this.
