Home » Sponsored » Pi Speakers » Stage 4Pi improvement
Stage 4Pi improvement [message #49007] Sat, 04 March 2006 10:39 Go to next message
LAL is currently offline  LAL
I have never been satisfied with some aspects of the Stage 4Pi performance. The dynamic range and "big" sound the speakers produce was their saving grace. The bass on mine was too boomy and woofer's frequency response gave vocals,both male and female an unnatural sound. There was never the sensation that the singer was in the room with you like good quality speakers can produce. On the other hand percussion and brass did have a dynamic quality that regular speakers couldn't produce. These qualities, both good and bad, were evident in various rooms and consequently were not room dependant(although the room and speaker placement still affected the sound). As a result I used the speakers primarily for background music and instrumentals. I have another system available to me which I used for "serious" listening.
My cabinets were constructed according to the basic plan for Stage 4's out of 3/4 baltic birch. They are well braced and lined bottom, back and one side with fiberglass. The unlined side was covered with Northcreek "Glop", a mixture of a softglue and drywall mud, used to dampen cabinet wall vibrations. I am a fairly experienced speaker cabinet maker and usually go the nth degree to produce a stiff well damped cabinet. Normally I use a constrained layer walls but certain design constraints required that I limit the Stage 4's to 3/4" thickness. I have never been satisfied with my Stage 4 cabinets. They radiated too much sound from the 15" woofer. I have also suspected that the use of the fiberglass to partially line the walls was insufficient to damped the back wave of the 15" woofer. So I finally decided to do something about it.
A couple of days ago I got some "Sonic Barrier" damping material from Parts Express. This is 1 1/4" thick multi layer dampening foam with a 1 lb vinyl barrier. It has an adhesive backing. I removed the existing fiberglass and then covered the bottom, top, back and sides(except the area on one side where the crossover board is attached)with the Sonic Barrier. Since it is charcoaled color it can be place on the wall behind the vent without being noticable. I then took about 1/3 of the fiberglass originally in the cabinet and used it to cover crossover and I place some directly behind the woofer, with alittle more on the bottom. After reinstalling the drivers I sat down for a listen.
The results were stunning. The response had smoothed out. The sound was much clearer. Voices now had a natural sound and on good cd's the performers sounded realistic and had that "in the room" quality that was so lacking before. Everything about this speaker is much better now. Had I not known what was done I honestly would not have recognized the sound as coming from the same speaker. I have listened for extended periods of time with no hint of listening fatique. Five sheets of the Sonic Barrier and about 4 hours of my time have absolutely transformed these speakers. I hoped for some improvement but never could have predicted the changes in clarity, smoothness and lack of distortion I am now hearing.
Maybe others are completely satisfied with their Stage 4's or my cabinets for some reason sounded differently than others, but if you are interested to see if you can improve your speakers get 5 sheets of the 1 1/4 Sonic Barrier and spend a few hours lining your cabinets, throw in a little fiberglass directly behind the woofer and see what happens. If it doesn't work for you all you will be out is about $125.00 and some time. If it turns out anything like it did for me you will be greatly rewarded. (Incidently so you will know my frame of reference for how a speaker should sound, my primary system used VMPS RM40's with AVA hybred electronics). I know audiophiles are sometimes prone to exaggerate attributing great differences in performance to difference between amps or cables. This is most assuredly not the case with the transformation of my Stage 4's. This has been a major league improvement and couldn't be more pleased about. I hope this post may help someone else make a similar improvement to their speakers and as a result to their listening enjoyment.
Re: Stage 4Pi improvement [message #49008 is a reply to message #49007] Sat, 04 March 2006 11:10 Go to previous messageGo to next message
Pfenning is currently offline  Pfenning
What amp/pre amp are you using on the Stage 4's ?
Re: Stage 4Pi improvement [message #49009 is a reply to message #49008] Sat, 04 March 2006 14:18 Go to previous messageGo to next message
I have used them with a NAD stereo receiver and an Outlaw A/V receiver
LAL
Re: Stage 4Pi improvement [message #49011 is a reply to message #49009] Sat, 04 March 2006 21:50 Go to previous messageGo to next message
Is this a promo? Doesn't sound like my Stage 4's at all....
Re: Stage 4Pi improvement [message #49015 is a reply to message #49011] Sun, 05 March 2006 10:23 Go to previous messageGo to next message
Matts,
A promo? Did you actually read the entire post? If your Stage 4's are entirely satisfactory to you that's great. Mine weren't to me. They are now however. The modification worked wonders for my speakers. I would highly recommend Stage 4's to anyone who asked. But I would also recommend they try the Sonic Barrier. Black Hole #5 might work just as well. The Sonic Barrier however is only about half the price. So is it a promo? Yes, I guess it is. A promo for the Stage 4 with Sonic Barrier or similar treatment to dampen the back way of the woofer. Now its is entirely possible that you somehow made a much more effective use of fiberglass in the construction of your Stage 4's and haven't encountered the same problems I did, although I believe I followed the instructions pretty close. It may also be possible that you have grown used to their presentation and have nothing else to compare them to. Whatever the case, if yours sound the way you want them enjoy it and don't take this post as a put down of the State 4's. I just think I found a way to make them better and I wanted to share it with Wayne and other owners since I am enjoying them now so much.
Re: No offense, Matts, but [message #49016 is a reply to message #49015] Sun, 05 March 2006 12:32 Go to previous messageGo to next message
I'm bothered by what many consider a perfectly reasonable suspicion of invidious commercial interest.
It's reached a point where every post praising something has to have a disclaimer. "I have no connection with or derive no benefit from..."
Why?
Consider this: If the positive comments concern a new product, or at least new to me, I'm happy the Internet gave me the opportunity to expand my awareness. If the opinion is that of a conscienceless salesman or someone with imperfect knowledge of the product, in either case, I trust my own ability to discover the truth. Quite often, I think, the poster might have valuable information coincident with a commercial interest.
The problem with Audiophiles is the same as with present-day society, everyone's afraid of everyone else!
With the exception of 'falsely crying FIRE! in a crowded theatre' I want my freedom of speech. And I want you to have yours.
Re: No offense, Matts, but [message #49017 is a reply to message #49016] Sun, 05 March 2006 13:06 Go to previous messageGo to next message
"I'm bothered by what many consider a perfectly reasonable suspicion of invidious commercial interest." ...."I want my freedom of speech. And I want you to have yours." Chill out & don't be bothered, then!
The reason I asked here, which is a firstl for me, is because the post seemed to follow a formula that I've seen in a lot of promotional lit on the web of 1)seriously overstating a problem I didn't see, then 2) leading through the dark valley, then 3) the "Eureka!" moment, then 4)the spend this pittance of an amount of $$ on this product and you'll be saved!! Here, even if there had been a disclaimer, I still would have wondered, but maybe it's just his style & it's fine with me.
I've had so many people tell me singers (or sax players, etc.) sound like they are right in the living room with us, that I just don't see this issue- but, if you or Wayne tries this stuff out & also say it's the bomb, I'll try it too!
Re: No offense, Matts, but [message #49019 is a reply to message #49017] Sun, 05 March 2006 18:34 Go to previous messageGo to next message
Jeez; an interesting post. You guys started to open the can of worms now. Because In my perception of the audio net lately; I find a sneaky suspician that everyone is on the make. Can't exactly put my finger on it with a clear certainty; but in this life I recognise when I see a hustle. And I am seeing a lot of tracks lately.
Re: No offense, Matts, but [message #49020 is a reply to message #49017] Sun, 05 March 2006 18:54 Go to previous messageGo to next message
"Chill-out"? I'm very relaxed towards LAL's post. Whether or not he has a commercial interest in the product isn't an issue for me. I don't believe he does. And what of a "disclaimer"? I have no use for "disclaimers". If we're questioning the integrity of a poster why believe a disclaimer?
We're also looking at a product that has information available beyond what LAL has told us. If, in this case, or any other I would be informed by the post, warmed by the description of the improvement and then decide for my self whether to pursue an investment.
The I.D. of the "profile" of the promotional post is something I wouldn't have thought of but is interesting. It does follow that plan, doesn't it? But then so does the legitimate tableau of discovering a problem and finding a solution.
My problem is that we have arrived at a time when: if you work for an American Corporation you are required to check your Bill Of Rights at the door; everyone has to be respectful of whatever any group other than white-american-born-males says or does no matter how outlandish or obscene; cleverness is cause for immediate termination; all of us have become needlesly paranoid and suspicious of everyone else' motives.
And we're nearly all too fat!
Re: No offense, Matts, but [message #49021 is a reply to message #49019] Sun, 05 March 2006 19:44 Go to previous messageGo to previous message
All right guys you caught me, I confess, I am the major stockholder in the company that produces Sonic Barrier. A couple of years ago I hatched a plan to increase the value of my stock holdings. I decided to purchase a Stage 4 Pi from Wayne, wait a couple of years then post on this forum how the cabinet performance could be improved by using Sonic Barrier. I thought if I could just seduce about 10 readers here each to buy around $120.00 worth of the product, that $1,200.00 of retail sales would net the company around $300.00 profit and consequently make my holdings that much more valuable, which in turn I could then sell and retire. I should have known someone would find me out. Rats, foiled again. I guess what did me in was trying to state the problem, show the process of working out a possible solution and the results of its implimentation. Oh well, maybe I should try it over on the Madisound forum, who knows I just might pick up a few bucks there before anybody catches on.
LAL
Previous Topic: FredT's looked so good and Shane complained, so...
Next Topic: The MOST SUB - Just for fun
Current Time: Mon May 13 23:00:07 CDT 2024
