Home » Audio » Group Build » SE 300B Project, Part 13 - The finished amp
Re: SE 300B Project, Part 13 - The finished amp [message #31926 is a reply to message #31925] Tue, 11 July 2006 11:33 Go to previous messageGo to next message
Unfortunately, I don`t have any experience with TVC - please, try it and report how it worked out!
For the input capacitance of CCS loaded (I assume that you use CCS?!) stage, we must "count" on large "Miller" capacitance. Although EC8010 data said Cag=1,9pF, Morgan Jones measured 4,6pF-4,8pF (!), and if it is actually true, you can expect ~ 300pF on the triode input! If you have "Valve Amplifiers 3" - it`s on the page 560 and around...
For C3g, data said Cag in triode 2,7pF, let`s say 3pF - then we can expect probably ~160pF of input capacitance.
Again, my opinion is to build the 90% of the amp "as is" (PS and output stage, and part of the input stage), then temporarily try EC8010 on its socket and its parts soldered on socket pins. Then try C3g version, with various options (Rk or LED bias, g3 connections...).
Only then you`ll know for sure what works for you.
Re: SE 300B Project, Part 13 - The finished amp [message #31930 is a reply to message #31926] Fri, 21 July 2006 04:19 Go to previous messageGo to next message
horny is currently offline  horny
hi Damir
I build the amp and tryed the C3g and ec8010 first i must say i build the amp with ux245 as output tube.
I used the C3g driver stage as you post here
and the ec8010 at 150v /20m.
The ec8010 is very good more hights and more bass then the c3g
but the hights are not sparkeling ,not loose. More like an transistor amp.
Very impressive but i think not for a long time.
The c3g has more fluidness (sorry for the strange talk) i try to explane sound thats not easy
the sound is also more clean
and there is a good balance in the whole freq.spectrum
So the c3g is staying
i like it !!!
For me this sounds best but i think that others may like the ec8010 more.
Then i tried the ec8010 and the c3g with the same operation points
interstage coupled.
I have amorphouse interstage tranny's from Tribute audio
the opt's are also amorpouse one's from the same builder.
The carractre of the tubes is the same now but no there is an naturalnes to the sound its smoother and more relaxed but still dynamic and very very clean.
I like the amp most with the c3g driver interstage coupled
its also a very simple set up.
Robert
Re: SE 300B Project, Part 13 - The finished amp [message #31931 is a reply to message #31930] Fri, 21 July 2006 07:46 Go to previous messageGo to next message
Hey, thank you for your report and congrats! I`m glad that you like C3g, yes - "fluid" is a good word to describe this sound...not too much "punch" and highs, but it depends on the way of bias (LEDs or Rk//Ck) and g3 connection a bit.
I think that I understand what you mean with "more bass and highs" but somehow "transistor" sound...boring and hard on the "long run". I have this feeling with 6C45Pi, for example.
Maybe (linear and neutral) C3g "uncovers" the real sound of DHT+OPT (output stage) and didn`t add "something" to it?!
Anyway, your version sounds interesting, especially with all this HQ "iron". I assume that you breadborded the amp...please, post some pictures when you finish it. Maybe we can put your (interstage) version in the schematics/projects section!?
Re: SE 300B Project, Part 13 - The finished amp [message #31932 is a reply to message #31931] Fri, 21 July 2006 08:38 Go to previous messageGo to next message
hi Damir
yes i think in 2 weeks i am ready with the complete amp
then i post a picture from outside and inside cabinet
i glow the 45 with dc and use Tent labs heaters
i have also Machmat heaters and they work also very good maybe better
and are cheaper www.machmat.com
the hum is 1mv maybe lower
this is needed because i use sensitive speakers
110db/1watt
here is a picture of the system
Re: SE 300B Project, Part 13 - The finished amp [message #31933 is a reply to message #31932] Fri, 21 July 2006 09:24 Go to previous messageGo to next message
Very nice!
Wow! :-) [message #31934 is a reply to message #31932] Fri, 21 July 2006 14:06 Go to previous messageGo to next message
Hey, if you can find some time in soldering pauses, describe us your system a little - especially the speakers.
That`s why I "insisted" on both driver versions breadbording...it isn`t easy to build totally "universal" SET amp...and I "voiced" it on two way rear ported JBL 4208...somewhat different then your horns...
Anyway, keep us posted about your progress.
Re: Wow! :-) [message #31935 is a reply to message #31934] Sat, 22 July 2006 04:56 Go to previous messageGo to next message
hi Damir
I build the whole set by myself
the speakers are 60cm Oris horns with AER md3 drivers.
The woofers are 15 inch bd15 in a b.r cabinet in front hornloaded with 80 cm Oris horns.
The woofers are active with a plxxo this is a line level filter direct behind the head amp.
So the caractre of the amp is given to the bass unit.
As bass amp i use a diy gainclone with very good power supply big trannie and 14 Black gates in super e cap config.
My diy dac is one tda 1543 nonoversampling type.
the turntable is also diy and weigts 38 kg.
(i have a picture if you like)
i do it with a link:
http://forum.audiofreaks.nl/index.php?topic=6571.0
scroll down and you see it
you cant see the motor on the pictures its a separate engine behind the turntable driven with a very thin wire
Stepup trannies are from Tribute Audio
and the phono amp is diy.
The passive pre amp are 2 (left and right separate)
autoformers from Tribute Audio.
Cables are all diy.
The sound of the speakers can i explane as it are magnifying glasses
the amp that drives them must be very good.
Every thing that is not right is direct audible.
if you feed them crap you get very much shit
If you give them a little hum you get enormouse hum in the room
It must be under the 1 mv and this is still a little audible.
but with the right aplifier they can sound like heaven
very very detailed with enormouse dynamics and pressure
also with 1,5 watt.
I have also an diy 300b amp
but i like the sound of a 45 more.
But thats just my taste
Re: Wow! :-) [message #31936 is a reply to message #31935] Sun, 23 July 2006 07:14 Go to previous messageGo to next message
Very impressive...serious and quality DIY stuff! Interestingly, you are "blessed" with many HQ transformers winders in Netherlands (Amplimo, AE, Tribute...), specialised shops and large DIY "comunity", so it seems...
Did you use "hum pot", or just directly connected Rk//Ck on the minus pole of the filament? I think that even with DC heating, with pot version you can adjust for lower hum...obviously necessary with 110db/W.
Re: Wow! :-) [message #31937 is a reply to message #31936] Sat, 29 July 2006 03:59 Go to previous messageGo to next message
hi Damir
i have build a 300b amp a year ago and this is with "normal"
dc just a schottky bridge and a 10000uf cap and a hum pot
i get here 1mv hum and it is quiet enough
but the the the sound with the heaters from Tentlabs or Machmat is much better
see this: http://www.tentlabs.com/Info/Articles/Heatingmethods.pdf
or http://www.machmat.com/sales/kits/index.htm
under miscelaneous and then vccs
regards Robert
Re: SE 300B Project, Part 13 - The finished amp [message #31941 is a reply to message #31912] Sun, 13 August 2006 04:04 Go to previous messageGo to previous message
hi Damir
Do you made any updates so far
i find the c3g sounds very good
but a little thin in the low mids.
The deep bass is very good with good punch
better than any driver i tryed
but voices have a little less body
i set screen 3 to anode this sounds indeed better than to ground
i have not tryed the led bias
for the rest is the amp pretty good ,clean not harsh go's deep very detailed and also the bass is very detailed
but voices may have more whoomp
do you have any idea what i can try?
Regards Robert
Previous Topic: Any new project ideas for winter?
Next Topic: Spare me some IXP10M45S ?
Current Time: Sun Apr 28 22:10:57 CDT 2024
