Home » Audio » Group Build » Schematic - first version
Schematic - first version [message #30146] Thu, 20 January 2005 06:18 Go to next message
Hosted by ImageShack, link:
http://img116.exs.cx/img116/283/g15rr.jpg
First version - simple one DN2540 CCS.
Schematic - second version [message #30147 is a reply to message #30146] Thu, 20 January 2005 06:24 Go to previous messageGo to next message
Hosted by "ImageShack", link:
http://img116.exs.cx/img116/9317/g26ds.jpg
Cascoded DN2540 CCS version.
Re: Schematic - second version [message #30148 is a reply to message #30147] Thu, 20 January 2005 07:02 Go to previous messageGo to next message
Thanks Damir; There is only one cap in the circuit? Have you accessed Douglas' new PS design by any chance? Thanks Again J.R.
Re: Schematic - first version [message #30149 is a reply to message #30146] Thu, 20 January 2005 10:36 Go to previous messageGo to next message
paba is currently offline  paba
Just wandering would the sound be better if you avoid the signal going thru the pot as shown in the schematic. Instead with a series shunt to ground config I think the signal goes thru a good quality resistor instead.
see:
www.lara.on.ca/~gandalf/
www.siteswithstyle.com/voltsecond/12_posistion_shunt/12_Position_Pure_Shunt.html
www.audiosold.com/passivepre.htm
cheers
Paul
Re: Schematic - first version [message #30151 is a reply to message #30149] Thu, 20 January 2005 11:26 Go to previous messageGo to next message
It`s hard to avoid the pot - various sources have various output voltages, say from 100mV to 2Vrms. Amplification of our preamp is about 16 or so, and if we don`t have the control, then output voltage from the preamp is 1,6-32Vrms! The typical sensitivity for the full output of power amp can be 1-2Vrms, sometimes lower. We can put the pot at the input, or at the output of the preamp, better on the input.
If too much amplification is the problem (high output sources), we can use lower-mu tube, say 12B4A, but then we must change the operating point...
Thank you [message #30152 is a reply to message #30147] Thu, 20 January 2005 11:48 Go to previous messageGo to next message
Thanks for taking the time to draw this.....Colin
No problem :-) [message #30156 is a reply to message #30152] Thu, 20 January 2005 13:31 Go to previous messageGo to next message
I`m glad if I can help a little, for now most of it depends on Duglas. But, after building a preamp, some of the people here would get first-hand experience with building tube circuits, CCS, power supply... and (I hope) we would reach 2nd level
Re: Schematic - second version [message #30157 is a reply to message #30148] Thu, 20 January 2005 13:40 Go to previous messageGo to next message
New PS design? No... IMO - in the begining (V1.0), it`s best to use simple PS design, later...who knows?
And about building from the schematics - just ask, I`m sure that someone would jump in with help/instructions/tweaks/opinions, etc.:-)
For the start, download DN2540 and 5687 data, plus the data for your favorite rectifier, for example EZ80/6V4, EZ81/6CA4...
PS Schematic -Version ? [message #30159 is a reply to message #30157] Thu, 20 January 2005 15:24 Go to previous messageGo to next message
I'm pretty lost right now as far as what PS we're using. Can someone please draw a schematic of what PS we're using? That would be too cool. We're about to drop some pretty pennies (and a few ugly ones too) on a choke and custom tranny. We need to make sure we're all on the same page.....Colin
Re: PS Schematic -Version ? [message #30161 is a reply to message #30159] Thu, 20 January 2005 17:01 Go to previous messageGo to previous message
Exactly; the original PS schematic uses the 6ca4 rec tube; Douglas suggested for the new iteration to use 6X4's, choke loaded.
Previous Topic: Potentiometer
Next Topic: trans order courtesy call
Current Time: Sat Apr 27 12:59:59 CDT 2024
