Home » Audio » Pro Sound » Channel jumping inputs fender to Matchless
Re: Channel jumping inputs fender to Matchless [message #27040 is a reply to message #27039] Wed, 04 May 2005 13:52 Go to previous messageGo to next message
walters is currently offline  walters
By the way thats alot for your time and informations on this
you helped me out alot.
Yea someone told me the same to use a isolation transformer with
polarity switch and 3 to 5 isolation outputs to not get ground
loops and impedance mismatching.
Ok so know we seen it from an impedance out look
But another way i see it is Tone because if i daisy chain or
Triple Y cord 3 different amps like a matchless amp to a fender to
a marshall those are all three different impendances that are
mismatched and the preamp section has a different VOICE design
so with daisy chain set up your putting the 3 different VOICINGS
designs in series where with a triple Y cord the 3 diffrent
voicing preamp designs are in parallel.
I guess its like 3 different frequecy response in series with
daisy chain and for Y cord is like 3 different frequency response
in parallel. Because the guitar is not just seeing the impendance
its seeing more past the impendace the design reactance of capacitance i would think by 3 different voicing either parallel
or in series.
Someone told me either the preamps can have a POLARITY im not
sure what that means really is the impendance out of phase then?
i know some of the preamps in fenders the outputs of the preamps
have a polarity and the output of the preamps is out of phase
from the normal channel to the vibrato channel. But if you daisy-
chain or Y cord amps we looked at the impedance of the amps in
both ways but what about this Polarity then?
I know Jimi Hendrix use to have a Triple Y cord setup and Daisy
chain this is SERIES/PARALLEL impedance and voicing designs
So the guitar sees
1.) the impedance either in series or parallel or both
2.) sees the polarity of the impedance
3.) and sees the capacitance of the preamp Voicing
The polarity im confussed about ?
and the Voicings of preamps im confussed about?
Thats alot for your time and information about this
Re: Channel jumping inputs fender to Matchless [message #27041 is a reply to message #27040] Wed, 04 May 2005 15:09 Go to previous messageGo to next message
In "daisy chain" system the last amp gets the "weakest" signal and the least high-frequency, you can observe that like series/parallel R and paralell C cascaded filters.
In every amp, every gain-stage inverts the phase, you have 3 different amps, and chances are that 3 output signals are very different, phase and "soundwise". But, with little experiments/placements that doesn`t have to be a bad thing, as I said, you can expect a "big" sound:-)
Again, try both ways, do a "Google" search/reading about it, and probably some "Y box" is in order... Good luck!
Re: Channel jumping inputs fender to Matchless [message #27059 is a reply to message #27041] Wed, 25 May 2005 16:11 Go to previous message
DMW is currently offline  DMW
Here's a good company and good source for A/B or ABY switchers/pedals.
Previous Topic: Need help fixing HRDx
Next Topic: Marshall DSL50 v DSL100
Current Time: Sat May 04 19:48:16 CDT 2024
