Home » Audio » General » Blind testing and what I would like to see done...
Re: obviously a reading problem on your part... [message #2144 is a reply to message #2143] Fri, 26 August 2005 11:49 Go to previous messageGo to next message
Very good explanation. In audio; what exactly would your opinion be that describes what we are testing for? Just to see a difference can be correlated with what about the equipment. I ask you because you have a good grasp of how to explain this stuff.
Re: obviously a reading problem on your part... [message #2145 is a reply to message #2144] Fri, 26 August 2005 13:30 Go to previous messageGo to next message
Tom touched on an item as to why you must do blind tests if the differences are small -- the placebo effect. Replace your 16ga zip cord speaker wires with megabuck boutique cables and give them a listen. Amazing! More detail, better imaging, firmer bass, etc. Or is it? I'll give you a dollar to a donut that in a DBT, you won't be able to pick between them.
Why double blind rather than single blind? Well, the operator can give you clues as to which item is under test, either inadvertently or on purpose. Remember the Coke/Pepsi taste tests? The tester gave the testee the other guy's product first, then his, knowing that the testee would usually pick the last item offered. One would presume that there is no such collusion at an audio club meeting, but single blind offers the opportunity for inadvertent giveaways.
Now, why shootouts don't work. Have you ever gone into a hifi store, auditioned something that sounded wonderful, but was absolutely unlistenabe after the second CD/record? The salesman biased your selection by playing HIS selection louder and with smiley-faced EQ. In the short time you listened, all of the psycho-acoustic clues brought attention to HIS selection, but you were not given enough time for your ears and brain to recognize that the audition was unfair.
Now, I am not suggesting that anyone here at ART would intentionally bias an audition, but the audition time is going to be too short for your brain to process what your ears are hearing, and again, the environment and music selection will not show each of the participants in the best light. You need at least a half hour to get a fair handle on a system. So, sit down for a while and listen. Play your favorite CD's. Get a good feel for what the system sounds like, then move on.
You don't need a base level to compare, you already know what the sound is that you would like to hear. You have to listen to a system long enough to see how it compares to the standard locked in your memory.
Bob
Re: obviously a reading problem on your part... [message #2146 is a reply to message #2145] Fri, 26 August 2005 16:17 Go to previous messageGo to next message
I absolutely agree concerning the time required to adapt to a new system. I actually favor more than a half-hour since the first hour all your brain is doing is distinguishing artifacts of the sound that are most obvious.
I have a question that begs the point of the discussion.
Do you yourself feel there is any merrit or possibility of actualising the term audiophile; does such a characteristic exist in reality. I mean the superficial definition that says one can be adept at perfecting the awareness of quality of sound beyond what an untutored person would be capable of.
Re: obviously a reading problem on your part... [message #2147 is a reply to message #2144] Fri, 26 August 2005 18:03 Go to previous messageGo to next message
tomservo is currently offline  tomservo
Hi
Good question.
Most of the time I have had to do A vs B listening, it has been in loudspeaker or driver development. In that case, I eventually reached sort of a dilemma.
After some time in development, one reaches a point where any change you make may well make a “difference” BUT often one then finds that the change actually “helps” some recordings but “hurts” others.
In which case, one case has different flaws than the other but there is often no way to tell which one is actually more accurate (that is assuming accuracy is the target).
By listening, your judgement A over B or B over A may depend entirely on what you play through them. Specific coloration’s in a persons speakers can even shape their taste in music.
At this point, I usually decided to go whichever way appeared to be the most accurate when considering the various TEF measurements.
It is kind of funny too, many people think of speakers as being “pretty good” reproducing the signal, yet if compared to even junky electronics, most speakers (measured the same ways) would appear to be seriously broken AND they spread the energy out in time significantly (even before being put in a room).
The problem is that some things that look like show stoppers in the measurements are hardly audible, other things are audible but are much more subtle in the measurement.
I would not want to scare anyone away from listening tests just because they are not blind.
In hifi just as it is in Pro-Sound, there is a huge degree of preconceived notion and expectation which is normally the result of a great deal of proper and costly marketing.
Even if one is aware, side by side comparisons often show large differences in loudspeakers, large enough to clearly “hear” the difference between acoustically based and marketing based performance.
For amplifier testing, on the live audio board amp shootout for example, when “blind” most (all but one) of the people (who were all in audio) couldn’t hear any difference between most modern pro amplifiers.
In a different blind test, through revealing horn speakers, no one present including myself could hear any difference between my Threshold Stasis and a QSC pl-236, until a medium volume, when the vastly larger power of the QSC was audible (in a positive way) in the dynamics. I used pro sound amps for “home” use from then on.
Many modern tube amps (as opposed to the older designs) tend to have very significant harmonic distortion, levels well above what are clearly audible in testing.
It also seems like pretty often the more exotic and expensive the amp is, the more exotic the reviewers language becomes and the greater the distortion and poorer the bandwidth is too.
Here, since many parts previously thought to be “bad” (like iron core inductors, transformers etc) have significant built in non linearity, many of these designs are refined by “taste”, balancing all the “flavors” into a gourmet’s reconstruction of the original input signal.
Personally, as opposed to a guitar amplifier etc where the right sound is everything, a re-producing amplifier is supposed to be a “straight wire with gain”, not create rich. warm tapestry with everything you feed in.
The flip side is that Tubes can also be made to deliver low distortion AND can have a small distortion spectrum (both very desirable from an accuracy point of view).
Do tube amps sound better? Is it because they are more accurate or are is it euphonic coloration?
I don’t think one can make a blanket statement about that or much else, it depends case by case.
Assuming that you have already past the point where differences are obvious, then what ever it is you want to find out by testing remember you need to at least have A or B to chose from. People have a poor acoustic memory, you can’t have much time between A and B and remember you can be easily fooled by not matching the levels first.
Listening for a fine detail improvement alone, after you have modified something is sort of like galloping really fast on a horse, unless you have 2 horses, there can’t be a race or statistical winner, even if your unable to imagine anyone riding any faster.
Does that mean that last little detail you modified helped?
Maybe yes, maybe no, the only way to know statistically (as opposed to just an unshakable belief) for sure is to compare side by side, “mit and mitout” as they say it Bratwurst country north of me.
When the differences are small enough, then you also have to remove prior knowledge and inputs from the senses unrelated to the pressure going in the ear holes.
There is a surprisingly large amount of money spent on things where the difference “goes away” when the test is limited this last way. Strong motivation to discredit the method.
Tom Danley
“What if” the current “gas crisis” was actually some sort of real shortage, or was not so subtle “pressure” from the Arab world (OPEC), circumventing our “unbiased” news media, instead of just another big profit grab like the other gas crisis’s in the past turned out to be? Umm.
I can live with that [message #2158 is a reply to message #2137] Mon, 29 August 2005 19:09 Go to previous message
Dean Kukral is currently offline  Dean Kukral
We are in basic agreement that the tests are not perfect because of environmental factors; also, one should purchase what one likes not necessarily what is accurate. Thousands of tube-lovers can't be all wrong!
Previous Topic: Tascam 133
Next Topic: Hey Charlie, man are you out there?
Current Time: Thu May 02 01:56:46 CDT 2024
