Home » Sponsored » OddWatt Audio » Phono Preamp First Look
Re: Phono Preamp First Look [message #94225 is a reply to message #94102] Sat, 14 August 2021 13:32 Go to previous messageGo to next message
When you are done with phono preamp,will you produce 2 phono preamp? The current one and the newer quieter one.
Re: Phono Preamp First Look [message #94228 is a reply to message #94225] Sat, 14 August 2021 21:25 Go to previous message
Hi, Most likely we will do both. The cost of the newer one will be a bit higher though as it uses some components that cost more and will need a larger chassis. We have not determined any prices yet as we are still beta testing. Additionally our costs to produce them are in flux now. Neither will be cheap. I don't know of any really high quality all tube phono preamps that are. We are uncertain if they will be initially offered as kits as well as built. The issue is predictability of the finished device. They have numerous components and actual soldering technique, component placement and wiring are really important. We don't want to be branded as a poor product because of a bad builder's technique.
Previous Topic: Phono Preamp Beta Testers
Next Topic: New Site is coming
Current Time: Tue Mar 10 00:49:30 CDT 2026
