Home » Audio » Source » Turntable thrust bearing (replacement) alternative
Re: Turntable thrust bearing (replacement) alternative [message #11972 is a reply to message #11937] Fri, 04 March 2005 13:49 Go to previous message
Daave is currently offline  Daave
Hi Dan-
Some corrosion on the post that the cueing cam assembly rotates on was preventing it from freely turning-so the catch lever would never "lock" into the ON position. Cleaning that up, removing all of the old grease that I could find got the ole LAB 80 running again. Now if I could just get the adjustment of the Eccentric screw on bottom correct to make it turn OFF when the arm gets to the middle of a record on "Manual" play!!! Garrard engineers really made things complicated-must have all been mechanical engineers!
Cheers-Dave
Previous Topic: Do I need a Phono pre-amp box???
Next Topic: Systemdek 2 bearing
Current Time: Mon Apr 29 02:22:29 CDT 2024
