Home » Sponsored » Pi Speakers » horn h290
horn h290 [message #81770] Sat, 19 December 2015 12:32 Go to next message
antonio7319 is currently offline  antonio7319
ciao
non riesco a trovare la tromba h290 / h290c
dove posso trovare le misure interne esatte per costruirla in legno
oppure ci sono alternative
Hello
I can not find the trumpet H290 / h290c
where can I find the exact internal measures to build in wood
or there are alternatives
Re: horn h290 [message #81772 is a reply to message #81770] Sat, 19 December 2015 13:52 Go to previous messageGo to next message
The shape is proprietary. I can tell you this though - It is oblate spheroidal at the throat and transitions to elliptic cylindrical at the mouth.
Re: horn h290 [message #81773 is a reply to message #81770] Sat, 19 December 2015 14:01 Go to previous messageGo to next message
Alternatives
Re: horn h290 [message #81798 is a reply to message #81770] Tue, 22 December 2015 11:13 Go to previous messageGo to next message
ciao
per il driver b&c de 250 va bene la tromba h 290
oppure va bene la b&c me45
Hello
for drivers b & c de 250 fine trumpet h 290
or fine the b & c ME45
Re: horn h290 [message #81800 is a reply to message #81798] Tue, 22 December 2015 12:27 Go to previous messageGo to next message
Most compression drivers work well with the H290C waveguide. That said, the B&C DE250 has been specifically tested and approved. The H290C waveguide and DE250 driver are ideal for one another.
Re: horn h290 [message #81801 is a reply to message #81770] Tue, 22 December 2015 12:33 Go to previous messageGo to next message
in europa non riesco a trovare la tromba h290c
in europe I can not find the trumpet h290c
Re: horn h290 [message #81807 is a reply to message #81801] Tue, 22 December 2015 15:19 Go to previous messageGo to next message
That's true. It's only available directly from us.
Re: horn h290 [message #81810 is a reply to message #81770] Tue, 22 December 2015 18:29 Go to previous messageGo to next message
come faccio ad acquistare da voi 2 h 290
I like to buy from you 2 h 290
Re: horn h290 [message #81811 is a reply to message #81810] Wed, 23 December 2015 08:11 Go to previous messageGo to next message
They're available on the π Speakers Shopping Cart:
Re: horn h290 [message #81812 is a reply to message #81770] Wed, 23 December 2015 08:14 Go to previous messageGo to previous message
quanto e il prezzo di spedizione e importazione per italia
and as the price of shipping and import to Italy
Previous Topic: 7 Pi build
Next Topic: 4 Pi plan
Current Time: Mon Apr 29 02:04:48 CDT 2024
