Home » Sponsored » Pi Speakers » One Pi Speaker
One Pi Speaker [message #75519] Wed, 13 February 2013 14:28 Go to next message
mrkazador is currently offline  mrkazador
Could I get the plans for the One Pi?
Thank you.
Re: One Pi Speaker [message #75520 is a reply to message #75519] Wed, 13 February 2013 15:11 Go to previous messageGo to next message
You've got mail!
Re: One Pi Speaker [message #75522 is a reply to message #75519] Thu, 14 February 2013 04:07 Go to previous messageGo to next message
Thanks! I have a question about the crossover if you don't mind. If I'm looking at the crossover correctly, there is 3 inductors. 2 for the woofer and one on the tweeter? and they all use the same value of 0.5mH?
What do you recommend for the resistor? A single or multiple resistors in series/parallel?
Re: One Pi Speaker [message #75523 is a reply to message #75522] Thu, 14 February 2013 08:20 Go to previous messageGo to next message
There is only one crossover coil, the 0.5mH inductor in series with the woofer. The other two coils on the schematic are the voice coils of the woofer and the tweeter.
Use a single 10 watt non-inductive resistor across the tweeter. And of course, a 10uF capacitor in series with the tweeter.
Re: One Pi Speaker [message #75525 is a reply to message #75519] Thu, 14 February 2013 13:42 Go to previous messageGo to next message
Thanks for clearing that up.
Re: One Pi Speaker [message #75554 is a reply to message #75525] Mon, 18 February 2013 09:56 Go to previous messageGo to next message
More information:
Re: One Pi Speaker [message #75592 is a reply to message #75519] Thu, 21 February 2013 22:11 Go to previous messageGo to next message
Thanks, a good read.
What do you think about a sealed slanted enclosure for the one pi? I'm limited in height for surrounds, max is 15". The bass will roll off sooner and I dont mind crossing the surrounds at 100-120hz. Could the baffle width also be changed from 12.5" to something like 14-15"? or would that cause some problems?
Re: One Pi Speaker [message #75601 is a reply to message #75592] Fri, 22 February 2013 11:13 Go to previous messageGo to next message
Don't run high-efficiency midwoofers sealed. If they're just being used as midrange drivers, that's OK but if they are to be midwoofers, they really need the excursion reduction from port tuning. Besides, the phase change is in the modal region where we don't care, and it might even be beneficial. So I see no reason to ever use sealed cabinets for high-efficiency designs like these. If you're going to high-pass them, crossover at the Helmholtz frequency.
Bill Epstein tried a slanted enclosure and said it sounded weird. I don't doubt it, because the crossover is a first-order design, which marketing types would call "transient perfect", and this kind of crossover depends on the drivers' acoustic centers to be vertically aligned. Said another way, the forward axis is normal to the baffle, which means a slanted baffle makes the forward axis shift. It's basically pointed in a direction perpendicular to the baffle. This is not unlike other properly designed speakers, but my point is this crossover type requires the acoustic centers of the drivers to be vertically aligned.
As an aside, I always bristle at the marketing phrases "time aligned" and "transient perfect". My smaller speakers use first-order crossovers and those have been dubbed "transient perfect". But then again, the higher-order crossovers in my waveguide speakers provide a similar acoustic phase, e.g. quadrature or less shift, within 90°. So I suppose I could promote this, as so many loudspeaker manufacturers do. But it always kind of rubbed me the wrong way. I like to speak in terms of the position of the forward lobe. Seems more appropriate, less like "marketing-speak".
I use first-order filters on my smaller speakers with dome tweeters because they have a little more excursion capability. This approach allows more overlap, which is helpful for maintaining the uniform horizontal pattern. Where the midwoofer pattern begins to narrow, it is blended with the tweeter pattern which is very wide. This provides nice uniform coverage, with the baffle setting the pattern at 180°, perfect for surrounds.
It may be useful to bring in a comparison with my larger waveguide speakers, since they are designed to be used together as mains/surrounds. The one π and two π loudspeakers make great main speakers too, but they are more commonly used as surrounds with my larger waveguide speakers as mains.
Voicing is similar between each model, with the midwoofers defining the body of the sound. My larger speakers use compression drivers on waveguides that are very natural and pure sounding, delicate but powerful at the same time. To me they sound a lot like an audiophile dome tweeter but with higher SPL capability. They are also more directional. But the narrower beamwidth of a waveguide, while attractive for mains, is a disadvantage for surrounds. So basically, I suggest that the smaller one π or two π speakers be used for surrounds, because their coverage pattern is more suitable for surrounds.
As for the crossover differences, waveguides should not use first-order filters because compression drivers have very limited excursion capability. You really have to limit out-of-band signals, and the waveguide chosen should also provide acoustic loading. Both are important for proper use of a compression driver. But since the acoustic phase relationships of all my loudspeakers are similar - first-order crossovers in my smaller speakers and higher-order crossovers in my waveguide speakers - summing is good and the forward lobe is pure in each of them. They are all "voiced" similarly, so they match well with one another in a system. The biggest differences between my smaller 180° speakers and my larger 90° waveguide speakers are their directivities and SPL capabilities.
Back to the topic of compression driver excursion - another aside - I've seen DIYers over the years ignore this limitation, and I suppose when running flea power tube amps, it is OK but it is risky on any loudspeaker presented any reasonable amount of power. Some DIYers try to run the waveguides much lower than is appropriate, in order to "match" directivities at low frequencies where all sources are omnidirectional. Another mistake is to use a shallow waveguide that doesn't provide adequate acoustic loading. Some even use both approaches, using a shallow waveguide and low-order crossover, trying to implement a "transient perfect" first-order crossover.
I would argue strongly against these practices because they completely defeat all the strengths of the horn/waveguide approach, and leaves the compression driver vulnerable to over-excursion. It severely limits dynamic range to use a low-order crossover and/or too low a crossover point on a compression driver, or to use it with a shallow waveguide that doesn't provide adequate acoustic loading. Without the proper crossover and acoustic load, distortion rises and risk of damage is high.
Re: One Pi Speaker [message #75608 is a reply to message #75519] Fri, 22 February 2013 15:06 Go to previous messageGo to next message
Is this the post you're talking about?
http://audioroundtable.com/forum/index.php?t=msg&goto=66231#msg_66231
I'm having trouble finding the right surround speaker that fits my space. Another option I was looking at is the JBL 8330 but I would have to build a whole new enclosure.
Re: One Pi Speaker [message #75610 is a reply to message #75608] Fri, 22 February 2013 15:45 Go to previous messageGo to previous message
Yes, that's the one.
Don't lean it back like that. Keep the baffle normal (perpendicular) pretty much lined up with the listeners. The baffle normal is the centerline of the forward axis. Aim this at the listeners. Horizontal movement is fine, you can even be way off-axis in the horizontal. But don't angle it in the vertical. Keep that within about +/-15°. So you can rotate the speaker as much as you want left and right, but don't rotate it up and down.
As for box dimensions, I think you can probably modify the cabinet shape somewhat, because it is small enough that internal standing waves are pretty high in frequency. They are high enough that the insulation inside the cabinet damps them pretty well. That's the biggest problem with mods of the larger cabinets - if you change the dimensions or the positions of the woofer or port, internal standing waves line up differently and there is the possibility of having a pressure node fall on the port or woofer, which results in response ripple. So if the builder chooses to modify a larger cabinet, I usually tell them to measure it to make sure that doesn't happen, and if they can't make measurements, don't do the mods. But it's safer in smaller cabs because the standing waves are higher and the insulation effectively damps them.
Just don't make the cabinet larger than about two feet in any dimension. Don't make it a tower. If you want to make it short and wide instead of tall and narrow, that's probably OK.
Previous Topic: 2225H midwoofers
Next Topic: 2Pi Tower Plan
Current Time: Mon Apr 29 08:26:38 CDT 2024
