Home » Sponsored » Pi Speakers » H290C Horn/Waveguide (Upgrade for the obsolete Eminence H290)
Re: H290C Horn/Waveguide [message #73777 is a reply to message #71929] Tue, 11 September 2012 09:24 Go to previous messageGo to next message
FYI, got the H290Cs yesterday and immediately installed them in my home rig. This is a temp setup, as I eventually intend to do a 3Pi build.
But, even in my non optimized rig, I can tell you the H290C sounds superb. In comparison to the QSC HPR 152i, which I think is excellent and have been using for several years, I hear less "distortion." That may relate to modes in the WG, not sure. The feeling is that the H290C is cleaner.
[The "rig" is: JBL 123A-1/DE250/H290C/4Pi crossover with 20dB attenuation as per Wayne's chart and C1 removed. Running with horn on top, not in baffle, temporarily.]
Re: H290C Horn/Waveguide [message #73809 is a reply to message #73777] Thu, 13 September 2012 09:37 Go to previous messageGo to next message
Glad your new waveguides sound good to you.
Interestingly, your impressions are the same as mine. I've measured the H290C and I've listened to it, and my listening impression seems subjectively more of an improvement than the measurements show. The H290C waveguide just really sounds natural to me.
Other people have said the same thing too. There's been enough time now for people to install their new waveguides and listen to them. The feedback I'm getting is very positive. I'm hearing a lot of similar opinions, using phrases like "smoother", "less distorted", "more natural" and "cleaner sounding".
The measurements are good, but the old H290 measured surprisingly good too, better than most waveguides out there. So by response measurements, you might not expect much difference between the Eminence H290 and the new Pi H290C, maybe not even enough to hear. While the H290C's oblate spheroidal / elliptic cylinder flare profile is the best shape, in my opinion, other profiles can be nearly as good provided they are close enough. But the H290C is better sounding, probably because it stays true to the OS/EC flare profile. Comparison of measurements don't really show this improvement as much as one might expect.
Of course, the measurements I'm talking about are just response and polar measurements, and they will only show very strong internal reflections in the form of response spikes. Smaller reflections won't show up in a response chart, and it may be that this is the difference. It would make sense, given the OSEC waveguide/horn generates the least (HOM) high-order modes. So I think the difference, while subtle, is audible.
I'm also pleased to hear your comparison of the Pi H290C with the QSC waveguide. I've received emails from a few others that compared it with the JBL and SEOS waveguides as well. I'm getting unanimous feedback that the H290C sounds better. This, again, I attribute to the pure OSEC flare. Other manufacturers deviate from it for one reason or another.
The new H290C waveguide just sounds better. I thought maybe it was just a proud papa thing, but since I'm getting feedback that the H290C sounds "smoother", "less distorted", "more natural" and "cleaner sounding" than the old Eminence H290 and other waveguides, I'm starting to think it isn't just me. Many people are reporting back positive results like this.
Re: H290C Horn/Waveguide [message #74648 is a reply to message #73809] Thu, 29 November 2012 10:54 Go to previous messageGo to next message
Here's a link to a thread that discusses physical dimensions of the H290C horn/waveguide:
It's handy for those that want to route a groove in their baffles for flush mounting.
Re: H290C Horn/Waveguide [message #75382 is a reply to message #74648] Tue, 29 January 2013 21:04 Go to previous messageGo to next message
Here's a snapshot of a four π loudspeaker with H290C waveguide:
http://www.pispeakers.com/fourPi_loudspeaker.jpg
four π loudspeaker
Re: H290C Horn/Waveguide [message #75909 is a reply to message #71929] Wed, 20 March 2013 18:45 Go to previous messageGo to next message
crescendo is currently offline  crescendo
Hi Wayne,
I'm new here (you may have seen me on diyaudio) and by way of searching many links of a chain, I found your H290C.
I haven't seen this question asked or answered yet, so I'll ask here. This is more a H290C question than a Pi Speakers system-question. I'm working on building a 2-way PA top with 12" woofer (probably the Beta 12A-II) and a 1" compression driver (Radian 475PB-16). Is there any reason(s) your H290C wouldn't work well for PA applications?
My next step is to discover how to implement alignment in the 2-way passive crossover system, as the CD horn will be directly in front of the woofer several inches. I have downloaded your crossover primer - might I find my answer there?
Best regards,
Justin
Re: H290C Horn/Waveguide [message #75922 is a reply to message #75909] Wed, 20 March 2013 21:26 Go to previous messageGo to next message
The H290C is the best 90°x45° horn/waveguide available, truly a no-compromise design. So naturally, I would suggest it for any DI-matched two-way speaker or constant directivity cornerhorn.
The loudspeaker models I make using that waveguide are the ones I found to be the best out of a few dozen that once made up my line, so I find them to represent the best of the best. I wouldn't make any other design choices than those.
That said, there are plenty of other similar components that work very well. An example is the Eminence Kappa line of drivers, which are very similar to the ones I use in some of my models, and which have been used by many DIYers on this forum. There are lots of others too, lots of ways to "do it right" but of course lots of ways to do it wrong too.
So my suggestion is to study the links in the Pi Speakers FAQ, especially those in the "Crossovers" and "Simulations and Measurements" sections. Also look at the "General Information" section, especially the post called "Notes for the DIYer". It has links to some of the most useful notes for designing speakers like these. For example, "Crossover optimization for DI-matched two-way speakers" describes my exact crossover design process including a video showing how to measure the forward lobe by finding the vertical nulls that mark its edges.
Re: H290C Horn/Waveguide [message #75929 is a reply to message #71929] Thu, 21 March 2013 08:46 Go to previous messageGo to next message
"But the upgraded H290C waveguide benefits from an upgraded crossover that has different values in a couple locations. Its impedance curve is different, necessitating the removal of capacitor C1 and installation of 16Ω resistor Rs. Check the schematic and board layout to identify and locate these components."
I slept through, as I have been doing since high school Very Happy , the technical details of the H290C and installed them without changes to the boards. Even before the crossover change I could hear an expanded soundstage in general and clearer exposition of the minor themes of a musical score. When I woke up and corresponded with Wayne I added the Rs resistor that softened the mids. Further discussion revealed that I also had to snip C1.
Once done, and liberally covered with rope caulk, the H290C are better-sounding than the Eminence: tonally more neutral with a clearer presentation of nuances like Violas under Cellos and brushes on Cymbals
Speaking of Violas:
What's the definition of a minor second?
Two violists playing in unison.
What's the definiton of "perfect pitch?"
Throwing a viola into a dumpster without hitting the rim.
Why do violists stand for long periods outside people's houses?
They can't find the key and they don't know when to come in.
Re: H290C Horn/Waveguide [message #75935 is a reply to message #75922] Thu, 21 March 2013 14:20 Go to previous messageGo to next message
May I ask the exact crossover changes required for both the 3Pi and 6Pi speakers? Also, it is difficult to judge the reflectivity of the H290C from the photgraphs on the website. Would you characterize it as flat, satin or glossy? Both of these factors would significantly effect the decision to replace the current Eminence waveguides or not.
Re: H290C Horn/Waveguide [message #75936 is a reply to message #75935] Thu, 21 March 2013 15:28 Go to previous messageGo to next message
The crossover change is simple: Remove capacitor C1 and add a 16Ω resistor Rs across the compresion driver. Alternately, there is a position on the board for this resistor so you can install it there if you want instead of hanging it across the driver terminals. The Rs position on the board is right beside C1.
Here are some additional comments by Bill Epstein, followed by waveguide design philosophy information:
The finish of production waveguides is satin. There are actually samples of many different ABS blends shown earlier in this thread, and that's why it's hard to tell what the finish is. There was a glossy blend I tried early on, and another blend that was a little less glossy but still shinier than what we eventually settled on. The final ABS blend I chose creates a black satin finish. An example is shown in the photo below, a picture of a four π loudspeaker with H290C waveguide:
four π loudspeaker
As an aside, I chose the ABS mixture largely for its dimensional stability and consistency. The mold shop gave me samples of waveguides using several different mixtures to evaluate, some that were really shiny, some that were more dull. Some held dimensions well, others less so. I placed a priority on dimensional stability, and the ABS blend that is most consistent tends to be less shiny, more of a satin finish.
ABS plastic is a mix of three substances, styrene, acrylonitrile and butadiene. The proportions can vary from 15% to 35% acrylonitrile, 5% to 30% butadiene and 40% to 60% styrene. By varying the mixture, you can achieve different properties. Higher styrene tends to make a shinier finish, but we found a little bit less tends to make the device more dimensionally stable, more uniform through the hold and cooldown cycles of the molding process. Since we prioritize dimensional consistency over finish, that sets the material to one with a surface that I would characterize as being satin black.
If you want a different finish, the waveguides can be painted. Enamel adheres very well to these waveguides, so you can spray paint them to be glossy, flat or even a different color.
Re: H290C Horn/Waveguide [message #76441 is a reply to message #71929] Tue, 23 April 2013 09:59 Go to previous messageGo to previous message
Hi Wayne,
I just recently noticed that H290C directivity sonograms are plotted over linear frequency scale. Do you have versions of the same plots but with logarithmic scale?
thank you
Previous Topic: 4pi flat pack, Rhino Line
Next Topic: 3Pi and 4Pi Plans Request
Current Time: Fri Apr 26 03:34:26 CDT 2024
