Home » Sponsored » Pi Speakers » Audition in Austin
Re: Audition in Austin [message #71682 is a reply to message #71681] Tue, 06 March 2012 10:41 Go to previous messageGo to next message
Wayne Parham wrote on Tue, 06 March 2012 09:36
Nick77 wrote on Tue, 06 March 2012 08:10
I used the three bolt pattern. I realized by lifting the driver up a little it made spinning the nut a little eaiser but im pretty sure removing a little plastic was neccessary. Confused
Yeah, the three-hole pattern is a bit dodgy. I never use that position because the two-hole mounts work perfectly, with no adjustment necessary.
Yup, you can say that again. Fell prey to the old more is better routine. Well now I know the two bolt pattern is good. Smile
Re: Audition in Austin [message #71683 is a reply to message #71680] Tue, 06 March 2012 11:25 Go to previous messageGo to next message
gofar99 wrote on Tue, 06 March 2012 09:26
Hi Nick, Which BGs are those in the new speakers? What crossover freq/slope did you use on them. I ask as I have a quad of BGs here that I never used for a still born project and it might just give me the push to finish it.
BG Neo3, not sure of the slopes, GR design.
Re: Audition in Austin [message #71691 is a reply to message #66232] Tue, 06 March 2012 17:45 Go to previous messageGo to next message
I had high hopes of using premium caps but took a major shellacking on the re-sale of my speakers. So ive ended up having to utilize some stuff on hand (hopefully not a major issue mixing caps??). I am planning on external XO's so i can tweak and upgrade as finances allow. Geeez those big caps are pricey.
A quick layout to determine size of board for building external XO box.
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4002-1.jpg
Re: Audition in Austin [message #71699 is a reply to message #71691] Wed, 07 March 2012 12:40 Go to previous messageGo to next message
mgalusha is currently offline  mgalusha
Very cool. I'm living vicariously through you since it's still too cold here to do much in the garage and start my Four Pi project.
mike
Mike G.
Re: Audition in Austin [message #71709 is a reply to message #71699] Fri, 09 March 2012 17:14 Go to previous messageGo to next message
Seemed like an inexpensive insurance policy against any potential ringing.
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4001-1.jpg
Re: Audition in Austin [message #71891 is a reply to message #71709] Fri, 23 March 2012 18:30 Go to previous messageGo to next message
Finally got some time to cut some mdf, pulled out the old trusty table saw and installed a new blade. Cuts thru mdf like butter. Smile
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4003-1.jpg
Picked up a new Jasper jig to do the circle duty.
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4002-2.jpg
Decided to use 1" thick mdf for a good solid cabinet and recess the drivers. Failed to think about creating twice the work. hehe
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4004.jpg
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4005.jpg
Re: Audition in Austin [message #71892 is a reply to message #71891] Fri, 23 March 2012 18:33 Go to previous messageGo to next message
If all goes well i should be able to get cabinets glued up this weekend. Yeah!!!
Re: Audition in Austin [message #71897 is a reply to message #71892] Fri, 23 March 2012 21:59 Go to previous messageGo to next message
Good work! I'm excited for you, 'cause you're almost there!
Re: Audition in Austin [message #71898 is a reply to message #71897] Sat, 24 March 2012 10:03 Go to previous messageGo to next message
Hi, Great looking wood working. My skills in that area are better suited to making orange crates. Smile
Re: Audition in Austin [message #71899 is a reply to message #66232] Sat, 24 March 2012 11:06 Go to previous messageGo to previous message
Okay now i am getting excited.....
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4002-3.jpg
Previous Topic: 4pi vs 3pi plans
Next Topic: 4pi Commercial Dinner Theater Build
Current Time: Wed May 15 12:23:16 CDT 2024
