Home » Sponsored » Pi Speakers » 2pi studio build (some progress)
2pi studio build (some progress) [message #65810] Sun, 23 January 2011 14:34 Go to next message
Here are a cpl pics of my progress. I have the box built and the baffle all cut and ready to go. I will install the insulation this week and then its just a wait til I can order the drivers. I made a screw up when I marked the two 1/2" holes for the tweeter and plugged the with dowels. Also my homemade circle jig has a low screw that scratched the face slightly. I filled it all with putty and flushed it all out. I will be using a hammer finish black paint on the box to match the rack it sits in so I am not to concerned about my mistakes. Live and learn eh?
http://img.photobucket.com/albums/v304/02TJ/IMG_2215.jpg
http://img.photobucket.com/albums/v304/02TJ/IMG_2214.jpg
http://img.photobucket.com/albums/v304/02TJ/IMG_2216.jpg
Re: 2pi studio build (some progress) [message #65812 is a reply to message #65810] Sun, 23 January 2011 16:35 Go to previous messageGo to next message
Looks good, thanks for posting your progress. We love pics here!
Re: 2pi studio build (some progress) [message #65813 is a reply to message #65810] Sun, 23 January 2011 16:42 Go to previous messageGo to next message
It's a great satisfaction to rub your finger across the junction of MDF panels and feel how tight and flush they are. Nice work!
If you've used Hammered paint before you know how delicate it is for at least 7 days. Spray and go away.
Re: 2pi studio build (some progress) [message #65815 is a reply to message #65813] Sun, 23 January 2011 17:16 Go to previous messageGo to next message
Thanks =) Yes I have dealt with it a bit and have learned essentially what you are saying =P I look forward to buying some more MDF and building the towers or a pair of these. I will finish my HT out with 1pi surrounds and another Table Tuba to even out my bass.
Re: 2pi studio build (some progress) [message #67769 is a reply to message #65810] Fri, 20 May 2011 22:54 Go to previous messageGo to next message
Well finally made some more progress. Got the insulation in, Tnuts are all in place with some 5 min epoxy. port cut painted and glued in. Will prob glue it together here in an hr. I so can't wait to hear it =)
Re: 2pi studio build (some progress) [message #67770 is a reply to message #65810] Fri, 20 May 2011 23:41 Go to previous messageGo to next message
All glued up. Now the 24hr wait begins =(
Re: 2pi studio build (some progress) [message #67772 is a reply to message #67770] Sat, 21 May 2011 09:09 Go to previous messageGo to next message
Now it's time for the good part!
Listening Smile
Re: 2pi studio build (some progress) [message #67774 is a reply to message #67772] Sat, 21 May 2011 14:47 Go to previous messageGo to next message
Do I leave them under clamp pressure the full 24hrs? I don't know whats suggested. They have been clamped for around 13hrs.
Re: 2pi studio build (some progress) [message #67815 is a reply to message #67774] Mon, 23 May 2011 17:14 Go to previous messageGo to next message
Clamp pressure length all depends on the glue you use. I think Tightbond or PL adhesive is going to be fully set (or at least enough to no longer need clamping pressure) in a few hours. But some white glues need longer.
Re: 2pi studio build (some progress) [message #67867 is a reply to message #67815] Thu, 26 May 2011 16:26 Go to previous messageGo to previous message
How do they sound?
VIRIBUS MARI VICTORIA
Previous Topic: Request 4Pi and 2Pi plans please
Next Topic: Three Pi push-pull sub plans?
Current Time: Fri May 17 20:44:16 CDT 2024
