Home » Sponsored » Pi Speakers » Midrange Horn
Re: Midrange Horn [message #71513 is a reply to message #71510] Fri, 24 February 2012 12:47 Go to previous messageGo to next message
I designed one, but it's really too large for home hifi use. Especially since corner placement allows for a much smaller horn to be used. That's the direction I went with the midhorn - It is used on my constant directivity cornerhorns, and its output blends with the woofer in the 100Hz to 200Hz range, smoothing room modes in that band.
Re: Midrange Horn [message #77787 is a reply to message #44366] Fri, 06 September 2013 16:16 Go to previous messageGo to next message
cookiemonster is currently offline  cookiemonster
How thick should the mounting plate be? Is there any minimum/maximum thickness? (Trying to convert to the MDF thicknesses I have available here).
Re: Midrange Horn [message #77790 is a reply to message #77787] Fri, 06 September 2013 20:35 Go to previous messageGo to next message
Any thickness adds to the front chamber volume, but the amount is slight unless the panel is really thick. Still, you don't need much. So limit it to 3/4". Sizes from 1/2" to 3/4" are fine.
Re: Midrange Horn [message #77799 is a reply to message #77790] Mon, 09 September 2013 07:49 Go to previous messageGo to next message
Thanks Wayne,
Did you ever try to run the horn with a simple sealed box behind the horn itself rather than enclosing the entire horn?
Re: Midrange Horn [message #77800 is a reply to message #77799] Mon, 09 September 2013 08:29 Go to previous messageGo to next message
Yes, and that's fine. Almost doesn't matter what shape the rear chamber is as long as it's large enough. So just make sure it's larger than 0.5ft3.
Re: Midrange Horn [message #77803 is a reply to message #77800] Mon, 09 September 2013 15:04 Go to previous messageGo to next message
Do your flatpacks include all the parts or just the hard-to-cut flare?
Re: Midrange Horn [message #77805 is a reply to message #77803] Mon, 09 September 2013 18:00 Go to previous message
Just the flare. The rest is kind of easy and probably wouldn't meric the cost. But the flare angles make it attractive for some to buy the flatpack kit. As horns go, it's as easy as it gets, but still, there are some angles to cut. I recommend starting off doing a mockup in cardboard for people that want to cut their own.
Previous Topic: How good is the 1Pi? Pretty good, I think.
Next Topic: I covet the 7Pi Plans...
Current Time: Wed Nov 25 02:32:12 CST 2026
