Home » Sponsored » Pi Speakers » 12pi bass horn plans
Re: 12pi bass horn plans [message #68875 is a reply to message #63739] Sun, 07 August 2011 04:42 Go to previous messageGo to next message
klmax is currently offline  klmax
new member, but Ive been watching and reading for years. It's time to build something. Can anyone tell me if the "current" plans are ver. II ?, and if the woofers sold are the new 500wt version, if not, will the 500wt version work with the cooling plug? Anyways, wondering if I can get the plans as well. Thanks, Klmax
Re: 12pi bass horn plans [message #68876 is a reply to message #68875] Sun, 07 August 2011 08:17 Go to previous messageGo to next message
The only plans we provide are for the v2. Our woofer is an OEM device made specifically for us, and with the cooling plug, it handles over 850 watts RMS continuous sine. It safely handles 1000 watts RMS using the more common EIA RS-426A rating method. This is over twice the power handling capability of the stock LAB12 woofer.
Re: 12pi bass horn plans [message #68879 is a reply to message #68876] Sun, 07 August 2011 13:35 Go to previous messageGo to next message
TruManagement66
Anyone know if polyfill has any benefit in a Horn enclosure?
Re: 12pi bass horn plans [message #68883 is a reply to message #68879] Sun, 07 August 2011 15:31 Go to previous messageGo to next message
No, it does not. Not a true horn, anyway. Truncated horns, tapered pipes and transmission lines pipes will benefit from stuffing material because it damps the standing waves. But full-size horns do not have sharp standing wave peaks that need damping.
Re: 12pi bass horn plans [message #69014 is a reply to message #63735] Sun, 14 August 2011 15:21 Go to previous messageGo to next message
Syskiyou is currently offline  Syskiyou
I would like to build a pair a 12pi's. Could someone please email me the plans? Thank you! Smile
Re: 12pi bass horn plans [message #69018 is a reply to message #69014] Sun, 14 August 2011 23:26 Go to previous messageGo to next message
You've got mail!
Re: 12pi bass horn plans [message #69031 is a reply to message #69018] Tue, 16 August 2011 01:00 Go to previous messageGo to next message
Hello Wayne, I hate it when I show my ignorance, but I'll be darned if I can find a file attached to your message. . . . Or did you send it to my personal email address? It is: Syskiyou@volcano.net
Thank you, I appreciate your patience.
Pat
Re: 12pi bass horn plans [message #69037 is a reply to message #69031] Tue, 16 August 2011 08:06 Go to previous messageGo to next message
The email has two PDF file attachments. If you did not get them, then something stripped them off. I can resend to an alternate address if you want.
Re: 12pi bass horn plans [message #69054 is a reply to message #69037] Wed, 17 August 2011 20:59 Go to previous messageGo to next message
Could you please send them to: Syskiyou98@yahoo.com
Thank you,
Pat
Re: 12pi bass horn plans [message #69055 is a reply to message #69054] Wed, 17 August 2011 21:12 Go to previous messageGo to previous message
You've got mail!
Previous Topic: Optional Drivers and Upgrades
Next Topic: Recessed baffle and speaker grills
Current Time: Wed Nov 18 00:50:03 CST 2026
