Home » Sponsored » Pi Speakers » 7 Pi bass cabinet
B&C DE250 packaging [message #52252 is a reply to message #52251] Thu, 26 June 2008 16:24 Go to previous messageGo to next message
There is one other thing I forgot to mention that may or may not be an issue. At least it is worth looking at.
I am very happy with the B&C DE250 in all areas except one. Their packaging for shipping really sucks. They are just put in a cardboard box without any padding. The driver is first put into a plastic bag, then set into the box, but no foam padding is used at all. In contrast, JBL uses a formed styrofoam basket to hold their drivers in the box, which pads them nicely and protects them from impacts. Eminence uses foam in place packaging, which snuggles foam around the driver and protects it. The B&C driver has no protection at all, and so they bump each other during transit and are extremely vulnerable to shock damage.
I don't recall if you got your drivers from me or not, but regardless of where you got them, it might be worth it to do at least a visual inspection. If they're damaged, send them back in for warranty service or replacement. If you can do some measurements, you can check them that way. If not, you might disassemble them and look for debris in the gap.
I've checked several drivers and in every case, I have found evidence of minor shock damage. There are chips in the magnet and small fragments in the bag. Most times, the chips are very small but in one case it was large enough I felt the need to measure the driver to ensure it was working properly. I expected it might not be up to spec, but it was. I've spot checked several, and so far, all have measured fine. But I always wondered how many times tiny particles from the magnet made their way down through the throat screen and into the gap.
Re: B&C DE250 packaging [message #52255 is a reply to message #52252] Thu, 26 June 2008 19:17 Go to previous messageGo to next message
PaulW is currently offline  PaulW
I've no way of measuring them myself, but because I did have one of the Omega Pro's damaged in transit,
Photobucket
all the drivers were visually inspected quite closely and nothing untoward was evident and there are no visible fragments in the gap under the diaphragms (just looked). The only point of concern I had about the DE250's was that mine didn't have screw terminals, just push tabs, unlike those shown on the spec sheet.
I really suspect the problem I'm having is due to a combination of my ears and the room.
Paul
Re: B&C DE250 packaging [message #52256 is a reply to message #52255] Thu, 26 June 2008 19:33 Go to previous message
I'm very glad to hear the DE250 drivers weren't damaged and look fine. I haven't had any troubles with them so far, they've all measured fine. I've just been concerned about the packaging for the reasons I mentioned earlier.
When they're working right, they're just sooooo smooooooth.
Previous Topic: Wayne, can I have the plans for the seven pi 18?
Next Topic: 4 pi x-over with Kappa pro 15lfa
Current Time: Sat Oct 24 22:40:27 CDT 2026
