Home » Sponsored » Pi Speakers » Corner Horn positioning "Sweet Spot" for listening...HELP
Re: Corner Horn positioning "Sweet Spot" for listening...HELP [message #49450 is a reply to message #49427] Tue, 09 May 2006 16:49 Go to previous messageGo to next message
Kim Schultz is currently offline  Kim Schultz
Hi Michael.
I live in Denmark and had the same worries about what speaker brand to choose.
In the end I ended up buying Eminence for the midhorn and tweeter, you can get these at good prices from Germany.
The woofers are old JBL 2225´s i got cheap from a local PA guy.
I have thought of upgrading the tweeters to B&C drivers, as they get very good reviews, and are affordable.
Regards
Kim
Re: Corner Horn positioning "Sweet Spot" for listening...HELP [message #49452 is a reply to message #49450] Tue, 09 May 2006 23:03 Go to previous messageGo to next message
For what it's worth, I like the B&C woofers but not as much as the JBLs you already have. Just make sure the cones are original and in good shape and you'll have the best.
Re: Corner horns without the triangular baffle [message #49461 is a reply to message #49428] Sun, 14 May 2006 07:30 Go to previous messageGo to next message
TomM is currently offline  TomM
I installed the rear panels yesterday, and also removed some of the fiberglass stuffing from the midhorns (i had them fully stuffed and wasn't sure I had allowed room for the midhorn to reach as low as it should). The bass, especially the midbass, now has better definition, and overall the sensitivity is noticeably higher. By higher sensitivity the bass is fuller at lower volumes now.
Re: Corner horns without the triangular baffle [message #49464 is a reply to message #49461] Sun, 14 May 2006 12:57 Go to previous message
Could be that the top and bottom sections vibrated a little bit like a diving board until you added the rear panels. The design is strong and rigid when all the panels are used, but if the back is omitted, it may leave the unbraced top and bottom sections free to vibrate.
Previous Topic: Cornerhorns for this room?
Next Topic: 2 pi and PiAlign program
Current Time: Sun Oct 25 03:22:10 CDT 2026
