Wayne Parham Messages: 19103 Registered: January 2001
Check the local electronic supply in your area. Ask 'em for heat sink compound. It's the same stuff you apply to the back of a power transistor when mounting it on a heat sink.
There r two poles of the voice coil. If we make one pole directly earthed to the body of the woofer then what will be the effect? will the body of the woofer not work as a heatsink?
