Home » Audio » Silicon Valley » Tubes versus Transistors (in 1976)
Re: Tubes versus Transistors [message #98301 is a reply to message #98300] Tue, 04 February 2025 19:44 Go to previous messageGo to next message
Hi,  The above is why with only one exception I use only polys in my gear and specify them in my projects.  Any elecrolytics are only in power supplies and are bypassed with polys.  In one of my latest phono preamps I even use polys in the latter stages of the power supply.  So I am in agreement with you.  Further if there is a way to eliminate a capacitor in a design (like between stages) I do that as well as long as the omission doesn't cause additional issues.
Re: Tubes versus Transistors [message #98320 is a reply to message #98300] Thu, 13 February 2025 13:48 Go to previous message
Something I should mention is that I try to have at least the "decoupling" capacitor
and previous capacitor as all polypropylene.
Another is that although there are some sonic differences between electrolytic
capacitors, I find a quite wide sonic differences between polypropylene capacitors,
so one needs to be careful to obtain the correct ones.
Sonic differences are caused by:
1. Dielectric materials used
2. Type of conductive "plate" material used
3. Thickness of the "plate" material
4. Termination techniques
5. Type of lead material used
6. Size of lead material used
7. Combination of materials combined, whether "plate", termination, or lead
There may be more upon in depth reflection.
cheers
pos
Previous Topic: A little something I cooked up
Next Topic: Crackling
Current Time: Sat Nov 21 02:22:55 CST 2026
