Home » Sponsored » Pi Speakers » Pi 4 questions
Re: Pi 4 with midhorn [message #50111 is a reply to message #50110] Sun, 01 October 2006 11:12 Go to previous messageGo to next message
I was worried about moving the woofer higher in the cab, but most of the low bass is coming out of the port anyway, right? If the port is left in the same position, same distance from the floor, the low end should not be affected, correct?
Re: Pi 4 with midhorn [message #50112 is a reply to message #50111] Sun, 01 October 2006 11:24 Go to previous message
At low bass frequencies, wavelengths are tens of feet long. So boundary reinforcement occurs even if the woofer is a couple feet away. Movement of a few inches or even a foot doesn't matter at all at very low frequency. When you get into the midrange and treble frequencies, that's a different story. At higher frequncies, inches matter.
Previous Topic: Wayne - What are the fundemental differences between ....
Next Topic: multiple driver manifold for horn loading...
Current Time: Sun Oct 25 01:02:31 CDT 2026
