Home » Sponsored » Pi Speakers » design plan for a tractrix horn using electrovoice EVM12L driver
Re: design plan for a tractrix horn using various drivers [message #40846 is a reply to message #40844] Fri, 04 April 2003 07:12 Go to previous message
Hornresp calculates mass rolloff as you've described. I think it will do a pretty good job for Adrian too. Either way, mass rolloff is a description of what can be expected from the horn when the diaphragm moves as a rigid piston. When the cone begins to flex - undulating across its surface - it will modify upper frequency response from that predicted by mass rolloff.
Previous Topic: Raw, Stark and unrefined... more of the same
Next Topic: Pi in Philly area?
Current Time: Sat Nov 14 15:13:51 CST 2026
