Home » Audio » Speaker » requesting opinions on fullrange array
Re: requesting opinions on fullrange array [message #20971 is a reply to message #20950] Fri, 03 June 2005 14:54 Go to previous messageGo to next message
DanTheMan is currently offline  DanTheMan
1) Does the subwoofer amp hum with no input?
yes
) Does the receiver hum when the sub amp isn't connected?
no
3) When everything is connected, does the hum come from the sub, the receiver or both?
both
4) Why do you run a signal back from the sub to the receiver instead of just going one way?
I don't have ony splitting cables. Should I get some to see if it will cure the problem?
5) Are you using an effects output like for an equalizer, that splits the preamp from the amp section of the receiver?
yes--I was thinking about changing it to running the speaker output to the high level input on the sub amp, but I was afraid that it would color the sound.
) If so, have you tried leaving the straps in place, and using another preamp output instead, like perhaps a tape monitor output?
Then you can't adjust the volume of the sub though--I want to set it at the right level so they sound even at any volume.
Thanks a lot again.
Re: requesting opinions on fullrange array [message #20972 is a reply to message #20971] Fri, 03 June 2005 15:11 Go to previous messageGo to next message
You could install a potentiometer after the preamp output, in the line to the sub amp.
Re: requesting opinions on fullrange array [message #20985 is a reply to message #20972] Mon, 06 June 2005 12:32 Go to previous messageGo to next message
Thanks! Unfortuneately I don't know what one is, but I'll do some research.
Re: Cheap Sub [message #20986 is a reply to message #20949] Mon, 06 June 2005 13:33 Go to previous message
Dr. Hsu has been doing nothing but engineering & making subs for the last 10+ years. He makes great products that would beat almost all home brews.
Let me put it this way: I like to home build my own speakers, but I didn't even consider building my own sub, i just bought a Hsu vtf-2.
Hope this answers your question!
-akhilesh
Previous Topic: Parallel Notch Filter Question
Next Topic: ESL web sites
Current Time: Mon Nov 16 06:02:45 CST 2026
