Home » Audio » Speaker » Completed My Voigt Pipes Today
Re: Please don't take this the wrong way.... [message #20165 is a reply to message #20164] Sun, 18 July 2004 19:26 Go to previous messageGo to next message
FredT300B is currently offline  FredT300B
Glad you liked all the eye candy. Something I forgot to mention in the picture captions: It's best to coat the entire piece with the 50/50 glue & water mixture and not just the rough edges. The mixture will, like water, raise the "grain" of the mdf, so you need to sand it thoroughly after it's dry, and if you have the patience it doesn't hurt to do a second coat and sand again. This will give you a smooth hard non-porous painting base that allows the automotive-like satin gloss that looks so good on a painted enclosure. If you do not use the glue/water mixture you're going to have to apply many many coats of paint and still have rough edges.
Re: Completed My Voigt Pipes Today [message #20181 is a reply to message #20146] Sun, 25 July 2004 22:12 Go to previous messageGo to next message
lon is currently offline  lon
When I got back here I saw this great project.
The slide show is excellent and the project writeup superb.
I'm studying a few of the Voigt designs and want to attempt
it in a bit. Over at the melhuish site (now called
www.fullrangedriver.com) TC has a project called Bigger Is
Better using the Voigt principle as well.
What I am scratching my head about is whether to use
the straight side or the angled side for driver mounting.
There is considerable writing on having slant fronts
on speaker cabs these days. Plus there are a few companies
using the slant front idea: Usher and Swans come to mind.
So my idea is to make a hybrid slant front Voigt pipe.
Is there any contrary information on this that I've missed?
Great job. :-)
Re: Bass Response [message #20534 is a reply to message #20155] Mon, 29 November 2004 08:32 Go to previous messageGo to next message
Mark is currently offline  Mark
I was in a room 25ft by 15ft and I had a good low base response now I am in a room 15ft x 12ft My bass responce has droped badly
Re: Bass Response [message #20535 is a reply to message #20534] Mon, 29 November 2004 09:59 Go to previous message
Where exactly in the room are your speakers located? They wouldn't happen to be two or three feet from a wall or corner, are they?
Previous Topic: Cancellation in car trunk
Next Topic: Enclosure for Fostex 167E
Current Time: Mon Nov 16 05:45:33 CST 2026
