Home » Audio » Speaker » Cool article on TNT-audio by a single driver nut...Thanx Martin!
Re: Cool article on TNT-audio by a single driver nut...Thanx Martin! [message #19783 is a reply to message #19782] Fri, 20 February 2004 10:22 Go to previous messageGo to next message
Let's listen to your setup at the next GPA meeting. Maybe we should arrange a time and place for another gathering.
Re: Cool article on TNT-audio by a single driver nut...Thanx Martin! [message #19784 is a reply to message #19782] Fri, 20 February 2004 10:32 Go to previous messageGo to next message
Martin is currently offline  Martin
Hi Jim,
I would be happy to look at whatever calculations you make w.r.t. the filter. You can post them here or e-mail me directly.
If you want to easily remove the filter from the network, all you need to do it pull out the resistor and put in a short piece of speaker wire effectively by-passing the inductor. Might save you the cost off a switch. Either way would work well.
Martin
Re: Cool article on TNT-audio by a single driver nut...Thanx Martin! [message #19786 is a reply to message #19783] Fri, 20 February 2004 13:10 Go to previous message
Good idea Wayne! Yes, let's arrange a time & place!
-akhilesh
Previous Topic: Check this out!
Next Topic: series, parallel and speaker sensitivity
Current Time: Mon Nov 16 05:28:56 CST 2026
