Home » Audio » Speaker » directivity
Re: directivity [message #18098 is a reply to message #18097] Fri, 12 August 2005 18:44 Go to previous messageGo to next message
rcw is currently offline  rcw
The point is that the three loudspeaker systems in question were all rated in the highest catagory in other performance aspects, and as Toole pointed out the systems in that catagory are very close in aspects such as on axis frequency responce, the question then being why should they produce that result on music tests?.
Toole concluded that it must be directivity since this is the single feature that stands out as different between the systems in question, the more narrow pattern excited the reverbrant field less and produced the subjective effect of "looking on" rather than being completely there.
I looked at that data again and it was when I was trying to get speaker workshop to work properly, and the gating perhaps gives results that are inacurate at the low end, when I get around to it I will repeat all tests and report.
rcw
Re: directivity [message #18099 is a reply to message #18098] Fri, 12 August 2005 20:09 Go to previous messageGo to next message
I did not read the Toole paper as carefully as you seem to, but I would have to say that there is not enough data to make the conclusions that you say Floyd made. In fact, my experince, and some unpublished data, imply the opposite. But either way your original comments implied that Toole claimed a "preference" for wider directivity, but now it seems that it is only a difference in subjective effect. Perhaps I should reread the paper in more detail.
I do appreciate the reference to the horn mouth paper. This is much like what I use in my text. I found some slightly different results and Johansen admits that it is known that the wavefronts do not adhere to the walls in many horns, but his analysis assumes that they do. This is a weak point in the paper.
In my text I do not assume this adhernce since I do the calculations using higher order modes which accounts for this effect. I would thus claim a slightly higher accuracy to my analysis than Johansens.
But I really am indebted to you for a coincidence that happened after I reviewed the Johansen paper. The next article in that journal is about using woven cloth as a HT screen, which I had also recently concluded to be supperior to a commercial screen for all the same reasons as in the paper. My new screen cost me $10 (bed sheet) and replaced an inferior $1200 perforated vynal screen! Can you beat that!
Re: directivity [message #18100 is a reply to message #18099] Sat, 13 August 2005 18:13 Go to previous messageGo to next message
It is always nice to find low cost options isn't it.
Seeing that the waveshape at the throat is not ideal I do expect that the dispersion in the horn is more than is really desirable, but I went on the principle that at the low end mostly the priciple longitudonal mode will be evident and that since the horn is short it the wave front would still have a considerable lateral componet due to throat scattering, something like it seems to work for Genelec
Re: directivity [message #18101 is a reply to message #18100] Sat, 13 August 2005 20:13 Go to previous message
It is true that at the low end most of the wave propagated down a waveguide will be the pure longitudinal wave because all of the other modes are below cutoff. The higher order modes are dissipated away from the throat depending on distance. These modes are known as evinescent waves and decay exponentially with distance. In a short waveguide these modes have not decayed sufficiently at the mouth so as to be ignored. I have long been aware of this issue, but have never had a chance to study it in any detail. I suspect that this is a reason why short waveguides don't behave as anticipated. If the waveguide is folded or bent at all, then the higher order modes are created again at each bend and we get the problem starting a new.
The thing about the screen that gets my attention is how much unnecessary hype there is now in Home Theater. Its the new "Monster Cable". Buy a multi thousand dollar screen if you want, I'll buy a bed sheet and a lot of DVD's instead.
Nice talking with you.
Previous Topic: Two New Line Array Kits
Next Topic: CSS FR125s project webpage
Current Time: Mon Nov 16 06:20:39 CST 2026
